Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 6 of 6
    Default force tilt trim relays
    seems most all force engines with tilt trim will have a relay issue at some point... I've HAD MY SHARE... tapping on the relay will often get it to work again once or twice... you can switch the relays as usually only one fails at a time IF you are in a situation where you have to get the engine up or down for use or trailer right then... there are some cheap made in china relays that will work for a minute then fail... there is one guy on ebay that sells them in pairs that are new old stock for like $20 for the pair... sorry i don't have a link but if you search "Force tilt trim relay" you should find him he has been selling them for years I fixed 2 boats with one pair I used the 2 new ones on one boat and then paired up the 2 good used ones I had for the other... so fixed each boat 4 $10 (I'm cheap) and being cheap bit me... i bought just one off ebay that was made in china and it lasted 2 trips out...
    if your tilt trim motor works just up or just down chances are it is the relay... BOTH relays have to be in place for it to work at all.. stupid i know but that is how it is on mine anyway
    just thought I would pass on what little i know since I have been reading this forum to keep my stuff running and never contributing
    May 2010
    Sebastian ,Fl
    2,417
    Default Re: force tilt trim relays
    IF your really cheap??
    You can rewire the boat and get rid of the relays completely.
    Just use a heavier wire and switch.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    My trim control is a mirco switch i can operate with my thumb in my controls... yeah 36 ft of 8ga wire proper terminals a 50amp momentary waterproof dp switch. wire ties, drilling some holes, and a couple hours.... yeah thanks that is a great idea ... I said I was cheap not a masochist
    May 2010
    Sebastian ,Fl
    2,417
    The older Chrysler/ Forces didn't use the relays.
    They also had a switch on the dash not the handle.
    Quote Originally Posted by Jerryjerry05 View Post
    Then my post wouldn't apply to those and your reply would not apply
  6. #6
    May 2010
    Sebastian ,Fl
    2,417
    Just putting out information like you did??
    You posted this> BOTH relays have to be in place for it to work at all..
    But before that you wrote this>
    What statement is true?? #2
    Just putting out there what I know.
  1. Bravo 3 Outdrive - Trim Sender & Limit Switch / Power Trim Tilt Relays
    By self-maintained-boater in forum Mercruiser Sterndrive Forum
    Last Post: 08-01-2017, 11:51 AM
  2. Tilt trim relays
    By toad in forum Chrysler Force Outboard Archive
    Last Post: 01-31-2008, 10:51 PM
  3. Trim relays 70hp force
    By nc randy in forum Chrysler Force Outboard Archive
    Last Post: 06-15-2007, 12:30 AM
  4. Tilt amp Trim Relays
    By phototom1 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-18-2006, 12:38 AM
  5. 92 Force 120 tilt cylinder seals and relays
    By Ed Hughes in forum Chrysler Force Outboard Archive
    Last Post: 04-21-2003, 11:00 AM
