High voltage output on 1993 175 HP Merc Outboard bad reg
danno
" HI my volatge normally runs
" HI my volatge normally runs around 13-14, now its bouncing up to near 16 on and off for minutes at at time. Is this an indication of a bad voltage regulator? Any harm in not replacing it right away? "
"danno,
High voltage can da
"danno,
High voltage can damage accessories such as gauges, tilt motors, lights, etc.
The stator might also be damaged if the regulator shorts out.
I have seen cases where the regulator actually began smoking and burned up altogether, along with quite a few wires.
I believe you have two regulators on that engine. You could disconnect the faulty one and run with just one regulator. That would be better than leaving the bad regulator connectd.
Tony"
" Need help.
We are in need
" Need help.
We are in need of a 175 merc.outboard
Motor.
We have a 1990 Champion 18 foot.
if we unable to find a engine for it
we are willing to sell it,it does come with
deepfinders,life wells and trolling
Motors. Thank you "
