Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 2 of 2
  1. #1
    Default 1999 40 hp force timing
    My 1999 40 hp force motor has a slight miss at WOT. I have cleaned the carb and replaced fuel line and connector and checked vent and all is good. I would like to check my timing but cant find the info needed. If i check the timing with spark plugs out and wires grounded with throttle wide open do i set the timing at 32 dbtdc. I see some people say to set it 2 degrees less if doing it this way. Im not sure to set it at 30 or 32 dbtdc. I have also replaced plugs (both plugs look the same with no fowling) and fuel filter as well and compression is at top of specs. At WOT its turning 4800 rpm and it has a slight miss every few seconds that brings the rpms down to 4500.The miss is just a split second. It runs absolutely perfect until 4600 rpm then it starts having the little miss. Not sure what else to test. I would like to get it running perfect and then try to change prop and work on getting the rpm up to the 5200 mark.Any help is greatly appreciated. THANKS
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,517
    Default Re: 1999 40 hp force timing
    Compression test?
    Pull the float bowl and check for crud?
    Pull the carb and check the reeds?
    The tiny rubber hoses on the motor, they can get clogged.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
Similar Threads
  1. 1999 40 hp force
    By busa in forum Chrysler Force Outboard Forum
    Last Post: 06-21-2017, 05:33 AM
  2. 1999 mercruiser 7.4 mpi timing issue
    By Old harley in forum Mercruiser Sterndrive Forum
    Last Post: 07-22-2015, 12:08 AM
  3. timing marks on a 40 hp mercury 1999 .4 stroke .
    By bazboat in forum Identifying Model / Year / Horsepower
    Last Post: 06-24-2013, 10:43 PM
  4. 1999 BF50 timing belt
    By dark_star in forum Honda Outboard Archive
    Last Post: 11-24-2008, 07:39 PM
  5. 1999 350 Mag MPI Timing Question
    By highflight2k2 in forum Mercruiser Sterndrive Archive
    Last Post: 06-18-2008, 06:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
