Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 2 of 2
    Default Do these timing values seem correct(force 40, 92-94)
    So the project and learning experience is A 1992-1994 Force 40 2stroke single carb and Its for a home built boat project and I got the engine free off of craigslist. WIN, I think. lol. So before I go digging into her the first thing I did was check the timing under these conditions: engine on land in a trash can, filled with water, prop is on, using the starting motor to crank the engine over, full battery, I also have 2 other batteries that I swapped around for the test. . . (so full battery was guaranteed), Plugs removed, and plug wires grounded out. The Timing light is set on 0. My timing reads 0 in neutral with the carb Closed and 28 at WOT on the left hand side of the 0 TDC marking on the fly wheel (still not in gear). Those readings are at the Zero line on the timing sticker.
    May 2010
    Sebastian ,Fl
    2,519
    Default Re: Do these timing values seem correct(force 40, 92-94)
    The 28 is probably right.
    Over on iboats Force forum are some specs.
    The first 3 posts are the repair and maint. of Force motors.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  1. What are ballpark parts values for 1990 Force 120 hp L-drive
    By dazk14 in forum Chrysler Force Outboard Forum
    Last Post: 06-08-2014, 01:21 PM
  2. Timing not correct
    By jamiel in forum Johnson Evinrude Outboard Archive
    Last Post: 10-06-2008, 08:58 AM
  3. Correct timing for 82 MPI
    By scott_duerring in forum Crusader Marine Archive
    Last Post: 09-13-2007, 03:33 PM
  4. Correct Timing
    By beatdaboat in forum Mercruiser Sterndrive Archive
    Last Post: 07-17-2006, 11:28 AM
  5. Correct timing for 351w
    By frank in forum Archive 2002-2006
    Last Post: 04-13-2004, 02:08 AM
