Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 7 of 7
  1. #1
    Default Are Anodes needed for fresh water only immersion ?
    I just bought a 1991 year old Tohatsu 30hp that was winter prepped and stored in
    barn for 15 years. It looks and runs good now but in the location where the anode
    is supposed to be there is nothing. I expect the boat will see contact with fresh inland
    water only about 125 hours a year and always hauled out and stored on trailer.
    Do I even need to be concerned with electrolysis or getting the proper anode ?
    BTW, which is the optimum anode for fresh water..... zink, alum, or magnesium ?
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    Default Re: Are Anodes needed for fresh water only immersion ?
    Depending on model, the anode is also a trim tab. Yes, you want an anode. The Factory anodes are zinc. What is your actual model/serial?
    Paul
    Buffalo NY USA
  3. #3
    The model of my engine is M30A3-346B as shown on the affixed engine tag.
    Tohatsu USA felt it was sold new around 1991 in a recent conversation.
    By the way... Calling the anode a trim tab to me sounds awfully goofy. I feel like if the boat is
    drifting off course one way or the other there needs to be a steering correction.
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    No. The trim tab, which is also a zinc anode, is used to compensate for prop walk and prop torque. That helps negate load on the steering, to make the motor easier to steer -- otherwise, the motor may prefer port to starboard or vice versa. 3C8602171 is the current part number. It attaches with a stainless bolt. MSRP is $13.13.
    Anodes are sacrificial, and always a good idea to reduce corrosion of other metals immersed in water. Yes, salt water is much more reactive, but we see a lot of corrosion in the Great Lakes as well. Particularly if you have a battery aboard, or have a metal boat, anodes are a must.
    In fresh water, the mag anodes would be preferred, but those weren't made for outboards back 25-30 years ago.
    Paul
    Buffalo NY USA
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,748
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  6. #6
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,748
    salt water you use zinc or aluminum
    fresh water use magnesium
    brackish water use aluminum
  7. #7
    Join Date
    Jan 2017
    Location
    Salem Oregon
    Posts
    85
    if you keep the boat on a trailer, use it only in fresh water, and you dont park it in a marina where shore power is available to other boats. you dont NEED an anode... but if you have a place for one on the motor, why not put one there? if in fresh water always, use magnesium for the best protection.
Similar Threads
  1. 02 125ELPTO. Exhaust out side anodes and water out holes not supposed to
    By JustDave45 in forum Mercury Mariner Outboard Forum
    Last Post: 09-11-2015, 09:22 PM
  2. Temperature rating for 440 chrysler thermostat raw water cooled (fresh water)
    By KavaKava in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-04-2013, 06:17 PM
  3. Water pump, fresh water side... Rebuild able or replace the whole assembly?
    By 1rider in forum Crusader Marine Engine Forum
    Last Post: 05-11-2013, 12:16 PM
  4. Replies: 10
    Last Post: 08-11-2011, 08:48 PM
  5. Raw water cooled flush with fresh water frequently
    By broggerp in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 03-13-2009, 04:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
