Results 1 to 3 of 3
    Default How to Trouble-Shoot Ignition?
    Hi there, just found this forum! Trying to assist my son with his boat, (97 Luhrs, Marine Power 350 inboards). The starboard engine lost the raw water impeller and overheated. Now that the impeller is fixed, the engine will only fire if you give it a squirt of ether (then it quits immediately). Checking the ignition I noticed that the spark appears yellow and weak. I am really not familiar with these engines, although I know my way around my outboards. Any ideas out there?
    Default Re: How to Trouble-Shoot Ignition?
    Sounds like a lack of fuel if it runs on starter fluid and you have spark. A spark is a spark as long as it jumps a spark plug gap. Color shouldn't matter, but then again I'm colorblind. How bad of an overheat was it? If it was prolonged and high heat etc. was a compression check done to assure the is no other mechanical / compression damage? For ignition troubleshooting I use a removed spark plug and connect the outer ground (threads or electrode) to negative ground on the engine. Crank it and watch for a repeating spark. I also have a spark tester that has an adjustable gap and is easier to use. Also visually inspect the plugs, wires, cap and rotor. Most ignition issues with the GM HEI will be either be from fouled old plugs, worn cap and rotor or plug wire routing error. The control modules in the distributors can go bad but tend to be intermittent and gradually get worse. I suspect something wasn't put back correctly during the repair...too much of a coincidence. I bet it is simple like the kill switch or oil sensor sender unit isn't hooked up causing the fuel pump to not run. Is the carb getting gas? You should be seeing the accelerator pump(s) squirting fuel when winging the throttle.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,241
    Ayuh,.... Ya obviously have a Fuel Delivery issue, not an ignition issue,.....
  1. Need help to trouble shoot over temp alarm on starboard head, 1989 Johnson 110
    By leaky in forum Johnson Evinrude Outboard Forum
    Last Post: 04-18-2015, 09:15 PM
  2. How to trouble shoot Ignition
    By Chris Craft Johnny in forum Crusader Marine Engine Forum
    Last Post: 08-23-2012, 10:02 AM
  3. 50HP Johnson J50PLSI Spark on 2 not on 1....how to trouble shoot.....just started!
    By slipnot52 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-18-2012, 08:47 PM
  4. Trying to trouble shoot clogged fuel system
    By punkyboater in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-13-2007, 12:31 AM
  5. Ignition trouble
    By danthony in forum Johnson Evinrude Outboard Archive
    Last Post: 05-11-2007, 12:20 AM
