Results 1 to 2 of 2
  1. #1
    Default Low RPM. Can't get up to full speed
    I had Hell's Caynon Marine build me a 22 feet jet boat in December 2013. It has a Marine Power 6.2l LS3 with a Hamilton pump jet. Full speed is about 55mph, until recently. I run the boat in salt water in northern British Columbia on the Portland Canel by Alaska. There is 344 hours on the engine. Engine was running great, I turned it off after running about 25 miles down the canel and when I started it back up it would only do about 30mph and the rpm's were at only 3800. Engine runs great just no power/rpm's. anyone else have this problem?
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,165
    Default Re: Low RPM. Can't get up to full speed
    check the fuel pressure in the rail.....
Similar Threads
  1. 90 Yamaha 4 stroke wont reach full RPMs and full speed
    By Keith P. in forum Yamaha Outboard Forum
    Last Post: 04-20-2016, 08:07 PM
  2. Speed of my boat at full speed
    By mnakkach in forum Yamaha Outboard Forum
    Last Post: 02-04-2015, 01:50 PM
  3. Boat only goes full speed once
    By wolverinesfan1 in forum Mercruiser Sterndrive Forum
    Last Post: 05-28-2014, 07:43 PM
  4. 1978 85hp evinrude full speed 12speed full speedstator
    By twiningtrain in forum Johnson Evinrude Outboard Archive
    Last Post: 06-27-2008, 03:12 PM
  5. Replies: 2
    Last Post: 02-20-2006, 07:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
