Click for Chrysler parts and manuals!
Results 1 to 4 of 4
  1. #1
    Join Date
    Sep 2008
    Location
    New York, NY, USA
    Posts
    71
    Default Distributor with 2 different springs in distributor - 1976 Chrysler 360
    not able to get over 3k RPM. reliable otherwise.
    opened distributor and noticed 2 different flyweight springs. one is much thicker/heavier than the other. Would the previous owner have done that intentionally? See attached.
  2. #2
    Join Date
    Sep 2008
    Location
    New York, NY, USA
    Posts
    71
    Default Re: Distributor with 2 different springs in distributor - 1976 Chrysler 360
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  3. #3
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    802
    I believe that is typical for Chryslers. Increases spring rate as engine RPM increases.
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,923
    The two springs are there for a purpose. It has an aggressive first stage of spark advance then the second spring kicks in and slows down the spark advance. Notice the one spring does not do anything until the advance has turned around 10-15 degrees
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
Similar Threads
  1. Prestolite distributor springs
    By LeisurLee in forum Marine Power Engine Forum
    Last Post: 05-06-2016, 07:49 PM
  2. Where to get distributor springs?
    By chris_holt in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 11-14-2010, 10:48 AM
  3. Distributor springs
    By bobv in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 10-26-2009, 02:25 PM
  4. Distributor springs for prestolite distributor
    By pat_the_pom in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-14-2008, 12:51 PM
  5. Distributor springs
    By mrpops in forum Archive 2002-2006
    Last Post: 09-25-2003, 10:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
