Results 1 to 19 of 19
  1. #1
    Join Date
    May 2007
    Location
    Posts
    395
    Default Mercruiser 8.1 smelly exhaust
    My buddy has a cruisers 340 with 8.1 mercruisers. The port engine only turns 3600-3700 rpm but the starboard runs to 4300. The exhaust smells like unburned fuel on port side as well. We see no gas sheen on water however. Any ideas on what the problem could be. We are thinking maybe one cylinder is down but I would think we would see a gas sheen in exhaust. As well we definitely have an issue with debris clogging filters in starboard side(the side that runs up to 4300). The problem is it appears there is no way to remove pickup tube to see if the pickup tube screen is clogged(if there even is a screen). That engine will run fine for 15-20 min then start to die out. It will idle but won't run up. If we let it sit for 5-15 min. It will run fine then do the same thing. Are we missing something about removing pickup tube? It can't come straight out because the deck is right above it.
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,292
    Default Re: Mercruiser 8.1 smelly exhaust
    clogged tank vent might do this
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,894
    Post a serial number.
    Does your 8.1 have a gen3 fuel cooler?
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  4. #4
    Join Date
    May 2007
    Location
    Posts
    395
    My buddy removed the fuel shutoff solenoid on top of the starboard tank. It was packed almost full of redish crud. He ran for 1/2 hour and we are cautiously optimistic the stumbling is fixed. Now to move to port engine to find out the smell and the rpm out of spec. Not sure serial number, Chris. I think he said boat is a 2006.
  5. #5
    Join Date
    May 2007
    Location
    Posts
    395
    Ok, back with some more info. Starboard engine appears fixed. Now, port engine has the smelly exhaust and it runs rough. To the point where after 20 min it just would barely run. We removed all spark plugs which were brand new last fall. They are all carbon fouled. Completely black after no more than 5 hours run time. We put new plugs in and started it up. We felt the exhaust manifold right where it bolts to the head. The starboard bank front cylinder was hot but the last three on that side were cold. We also think the second cylinder back on the port side of that engine isn't firing. So 4 out of eight not working. We pulled a coil from the good motor but it still didn't change. We changed ecm from good motor but no change. What would be causing the motor to foul plugs so fast and why are so many cylinders not firing? Compression test was ok.
  6. #6
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    1,273
    I would hazard a guess that the same crud has fouled the injectors. If the nozzles are dribbling and not atomizing, you would get a lot of unburned fuel. I would pull all the injectors and have them cleaned and tested.
    Practicing the ancient art of ren-ching
  7. #7
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,894
    Quote Originally Posted by sammi View Post
    Put a fuel pressure gauge on the rail and report your findings.
    Find the serial number.
    Chris
    Jersey Shore.
  8. #8
    Join Date
    May 2007
    Location
    Posts
    395
    Chris, We were looking for that fitting but didn't see it. Where would we find it?
  9. #9
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,894
    Right behind the coolant reservoir. You have to loosen the reservoir and pull it forward.
    Chris
    Jersey Shore.
  10. #10
    Join Date
    May 2007
    Location
    Posts
    395
    Awesome. Thanks.
  11. #11
    Join Date
    May 2007
    Location
    Posts
    395
    Ok, we removed the fuel rail completely and found injectors clogged up with crap. We cleaned rail, installed new plugs and injectors. Now they all fire up but when we start it it runs for a few seconds and dies, start it up again and it runs a little longer and dies, then runs a little longer still, then dies, till finally it runs. We put a gauge on the rail and it read 40ish but the gauge was leaking badly so we quit until we can get a better gauge. Any idea what would cause this. It seems like it losing prime somehow. Sorry Chris, I still don't have a serial number but pretty sure it's after the cool fuel paint problem if that is what your getting at.
  12. #12
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,894
    Unless your cooler is around 2-3 years old, you have a paint problem. Pull the regulator out of the cooler and see what comes out with it.
    It is important that you get a good fuel pressure gauge on this engine and take readings at idle and while you are running under a load.
    Chris
    Jersey Shore.
  13. #13
    Join Date
    May 2007
    Location
    Posts
    395
    Will do Chris. Good to know. I thought the problem was fixed by 2006.
  14. #14
    Join Date
    May 2007
    Location
    Posts
    395
    Ok, got a good fuel pressure gauge and at when we turn key to on to engage fuel pump but don't start it, it reads 38. When we start engine at idle it rises to 75!
  15. #15
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,894
    75 psi is way too high. On the back side of the Module is a brass plug(High Pressure relief valve). Inside that plug is a spring and a check ball. Pull the plug and the spring and don't loose the ball. Look at the plug, you will see lines cut in it from the spring. Sand the brass plug smooth. Reassemble the plug, ball goes in first, the spring goes on the plug and then screw it in with some thread sealer.
    On top of the module is a regulator held in with 8mm bolt, remove the regulator and clean out the paint.
    You should replace the top of the module with the updated one and have the injectors cleaned.
    Once you get this all cleaned, retest and report what you find. Fuel pressure should rise to around 43psi with the line off the regulator and run around 38-39psi at idle.
    Anything over 43psi is a clogged regulator. Anything over 60psi is the pressure relief on the back side of the module. While the engine is at idle.
    The fuel pressure will go over 100psi while running down the bay when the relief valve is stuck.
    Chris
    Jersey Shore.
  16. #16
    Join Date
    May 2007
    Location
    Posts
    395
    Thank you Chris!
  17. #17
    Join Date
    May 2007
    Location
    Posts
    395
    Ok, talked to my buddy who owns the boat and he says it doesn't have the Gen 3 cool fuel module. It's a 2003 and he has the kind that looks like a oil cooler. Long and thin. Does that have a similar relief valve somewhere?
  18. #18
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,894
    This is why we need a serial number.
    So, It has a gen 2 cooler. There is a regulator on that cooler and inside the regulator is a small screen that will clog and shoot the pressure up.
    Chris
    Jersey Shore.
  19. #19
    Join Date
    May 2007
    Location
    Posts
    395
    Ok, back to this problem. Serial number om314427. 8.1 mercruiser. We put new regulator in and have a pressure of 43 it idle. Key on engine off 50, then when pump shuts off it holds at 34. What our problem is now is it is hard starting and once it does start it only runs for 4-5 seconds then shuts off. Fuel pressure holds at 43 while running. Swapped IAC from side to side, no change. When it's trying to start it reminds you of a carbed engine with a stuck choke. Like it's catching on most cylinders and winding up but just won't start. Then it finally does.
Similar Threads
  1. Mercruiser Exhaust options
    By twoods19 in forum Mercruiser Sterndrive Forum
    Last Post: 08-13-2014, 12:20 AM
  2. Mercruiser 3.0 Exhaust Manifold too hot????
    By redfiveshoe in forum Mercruiser Sterndrive Forum
    Last Post: 06-09-2014, 04:52 PM
  3. Need Mercruiser exhaust Y pipe
    By ebizsearch in forum Mercruiser Sterndrive Archive
    Last Post: 06-03-2009, 11:48 AM
  4. Mercruiser exhaust riserelbow
    By kedwards in forum Mercruiser Sterndrive Archive
    Last Post: 09-11-2008, 07:35 PM
  5. Mercruiser 74 MPI Exhaust Steam
    By billybob59 in forum Mercruiser Sterndrive Archive
    Last Post: 12-28-2006, 05:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
