Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 6 of 6
Thread: 85 hp force
  1. #1
    Default 85 hp force
    I have a 89 85 hp force ive replaced the water pump and put carb kits on all the carbs it will start only if i hold the choke and then it dies can anyone help figure out whats wrong
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,599
    Default Re: 85 hp force
    Sounds like the rebuild wasn't done right??
    The air screws set at 1 and 1/8th turn out?
    Missing gasket?
    Fuel pump diaphragm bad?
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    88 Bayliner with 2002 225 HP Mercury
    Buy American made Cars and Trucks!!!Towing insurance,get it.
    In Scenic Beautiful Sebastian by the sea Florida
  3. #3
    Thank you jerry i know the carb kits are right it was only a bowl gasket and i set the mixture screw at one should it be 1 and eighth
  4. #4
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,599
    I should have said: the carb cleaning might not have gotten the low speed system cleaned right.
    The initial setting should be 1 1/8 to 1 1/2
    Then adjusted from there.
    The factory sent out a bulletin that all 85' 1985-1990 should be set at 1 turn out and left there.
    BUT!! I've found some work better at 1 1/8
    One of my customers his 85/85 wouldn't run unless they were set at 3 turns out.
    Set at 1 1/8 and adjust from there.
    Motor warm and in water, preferably in gear.
    RPM's about 750-800 (final setting)
  5. #5
    Thanks again jerry ive notice something else im wondering if my fuel pump diaphragm is bad because when i pump my bulb the gas pours out of the bottom carb
  6. #6
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,599
    That's the needle in the carb not seating.
    Clean the carb.
    Then install a filter between the pump and the carb.
    Fram G-2 G-3 G-12
Similar Threads
  1. Newbie here. Force 125 to Force 125 straight swap?
    By Hallass in forum Chrysler Force Outboard Forum
    Last Post: 07-27-2016, 05:30 AM
  2. Can I swap a 1989 force 90 hp with a 1989 force 120/125?
    By TomCalab in forum Chrysler Force Outboard Forum
    Last Post: 12-04-2014, 09:19 PM
  3. what force do i have ,,please help
    By sadman in forum Chrysler Force Outboard Forum
    Last Post: 07-04-2011, 06:48 AM
  4. 95 Force 70 hp
    By slik in forum Chrysler Force Outboard Archive
    Last Post: 05-08-2008, 09:02 PM
  5. Force 85
    By nottuskram in forum Chrysler Force Outboard Archive
    Last Post: 04-23-2008, 07:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
