Click for Volvo Penta parts and manuals!
Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2017
    Location
    Portugal
    Posts
    4
    Default Is this an AQ140A engine? and what model is this drive?
    Hellow to everyone! Congratulations to this great forum!
    I bouth an old boat made of fiberglass witch im trying to restore and need HELP to identify what engine and sterndrive do i realy have on it!
    here i send somme fotos
    BTW: if is there somme portuguese people in this forum?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	16229   Click image for larger version.
ID:	16230   Click image for larger version.
ID:	16231   Click image for larger version.
ID:	16233   Click image for larger version.
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,800
    Default Re: Is this an AQ140A engine? and what model is this drive?
    That is most definitely a 280 model stern drive.
    Take a look here to help you determine which OHC 4 cylinder engine you have.
    http://www.marinepartseurope.com/en/...neEngines.aspx
    With all of the corrosion that I see, I will suggest that you proceed with caution.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  3. #3
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,790
    Might not be corrosion since I once saw a Volvo drive that had been painted with black anti fouling that looked like that :-(....
    Still "proceed with caution" !!! Good advice with any used drive, especially one of that age. Failing to properly maintain the "zincs" can result in very expensive repairs.
    BTW... replace the bolts that hold the swim platform. The rust stains on the hull are an indication that the bolts, if stainless, are cheap hardware store types and not "marine". Those bolts (hopefully and not screws!) are likely to fail at an inopportune moment. I've see it happen. Be sure the holes thru the transom for the bolts are sealed otherwise you are looking at future (if not present!) dry rot in the transom at the bolt holes.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  4. #4
    Join Date
    Jul 2017
    Location
    Portugal
    Posts
    4
    thank you very much for the good help! i will have very very caution because i ve notice that there is a LOT of work to do in the boat and i really think that it has a rotted transom... my project is to first try to put somme good work on the engine like try to replace somme parts and put it at good condition, then ill try to restore this old hull and thats another story that i will try to make a post in this forum. if i do not get the engine running, well i think i will sell it for parts and recover somme money back that could help me get another one good engine..
    anyway i will put this engine out and share here somme fotos! Thans again! im gonna try to find what OHC engine is..
  5. #5
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,800
    I would first examine the structural transom core and the stringer cores. If the core material is bad, this quickly becomes an expensive and labor intensive project!
    Proceed with your eyes wide open!
    Portland, Oregon
  6. #6
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,790
    "becomes an expensive and labor intensive project!".... and not one for the inexperienced.
    Capt Bob
    1972 22ft Bristol
  7. #7
    Join Date
    Jul 2017
    Location
    Portugal
    Posts
    4
    well thank u by the hope you give me Sandkicker... but i realy want to do something about this boat and engine, and for now im gonna start slowly and step by step, reading and learning and asking the people who know it for good advices. im not afraid of hours and hours of sanding and bonding and glassing... its a hobbie, not a Job...
    The old fishermans in my hometown, they say this is a good old engine and by now im waiting till the end of August to receive a visit of a good friend german (who is a Mecanic Enginheer and also a Skipper) to see if we can put somme good life on this old engine..
    its not been easy for me to realy see what HOC cylinder engine i do have... can u help me how to find?
    Here i send somme more fotosClick image for larger version.
ID:	16288Click image for larger version.
ID:	16289Click image for larger version.
ID:	16290Click image for larger version.
ID:	16291Click image for larger version.
ID:	16292Click image for larger version.
  8. #8
    Join Date
    Aug 2016
    Location
    North Delta BC
    Posts
    22
    Quote Originally Posted by nel.edgar View Post
    For what it's worth....I have never seen a AQ140a...but I have a AQ145a in my boat and it looks exactly the same as yours..same heat exchangers, dual carbs etc...not sure what the differences are between the two...if any.
    1982 Glasply 1800 Volvo Penta AQ145a 280
Similar Threads
  1. OMC Sea Drive model year ??
    By JayB in forum OMC Sterndrive and Inboard Forum
    Last Post: 11-28-2016, 08:38 PM
  2. Why would prop turn only at idle - 231 interceptor engine and a Model C Eaton outer drive
    By copelandg in forum Ford Interceptor Marine Engine Forum
    Last Post: 10-03-2012, 08:45 AM
  3. AQ140a Engine Overheating Issues - Frustrating!
    By gsvh747 in forum Volvo Penta Gas Engine Forum
    Last Post: 08-30-2012, 01:44 PM
  4. Model of engine amp drive unit
    By ebizsearch in forum Mercruiser Sterndrive Archive
    Last Post: 06-01-2009, 11:19 AM
  5. AQ140a engine swap
    By marshy66 in forum Volvo Penta Gas Archive
    Last Post: 11-14-2007, 12:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
