MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 11 of 11
    Apr 2016
    Moncks Corner, sc
    16
    Default What block is me Mercury 25 Hp?
    Is my 25 Hp Mercury block the Mercosil block? I'm wanting to rebuild it but not sure what block I have. My serial # is 0D293494 If it helps.
    May 2007
    Inverary, Ontario, Canada - The Great White North Eh!
    9,127
    Default Re: What block is me Mercury 25 Hp?
    Serials 0G202750 and "below" (which is yours) are chrome and can NOT be rebored or honed. 0G202750 and "above" are the Mercosil bores that can be rebored to a max of 30 thou over.
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
    Apr 2016
    Moncks Corner, sc
    16
    Quote Originally Posted by galamb View Post
    So im screwed if my cylinder is scratched?
    May 2007
    9,127
    Pretty much. Even the Mercosil blocks are a pain to do and not many shops will touch them.
    And even if you could bore it/hone it, by the time you replace the pistons, rings and whatever else you could probably find another powerhead cheaper.
    Just a set of rings will set you back almost 200 bucks (per piston).
    Graham
    Nov 2011
    tennessee
    2,898
    Mercosil blocks have "Mercosil" cast on top of block and there are some earlier models/serials with Mercosil block(1994-04)The earlier models are serial# 0D278000 and up. Rings are $45 a set too...
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  6. #6
    You are better off with the block you have the chrome is pretty tough. Pull the pistons and see what you have a lot of times they are OK with a little cleaning.
  7. #7
    Apr 2016
    Moncks Corner, sc
    16
    Quote Originally Posted by flyingscott View Post
    Im going to post pics in a few min
  8. #8
    Apr 2016
    Moncks Corner, sc
    16
    What does the big M stand for?
  9. #9
    M=Mercury. On the #1 cylinder, that is the top one, over on the throttle assembly side it will say either Mercosil or nothing. It is physically cast into the block if it is there.
  10. #10
    Apr 2016
    Moncks Corner, sc
    16
  11. #11
    Apr 2016
    Moncks Corner, sc
    16
  1. 1976 9.8hp mercury 110 cilinder block removal?
    By TG.Vollebregt in forum Mercury Mariner Outboard Forum
    Last Post: 05-30-2014, 03:02 PM
  2. 02 mercury Is the 50hp 2 stroke the same block as a 60hp
    By Toddadcock in forum Mercury Mariner Outboard Forum
    Last Post: 06-24-2013, 07:14 AM
  3. 1992 Magnum III Block compared to 2001 Mercury XR6
    By jonkell in forum Mercury Mariner Outboard Forum
    Last Post: 03-29-2012, 07:43 PM
  4. Mercury 200 Opti Reed Block Gaskets
    By BillYoung in forum Mercury Mariner Outboard Archive
    Last Post: 06-20-2007, 08:02 PM
  5. Mercury Inline Reed Block Differences
    By Kirk Spradling in forum Outboard motors archive 2000-2004
    Last Post: 06-12-2002, 12:23 PM
