Results 1 to 2 of 2
Thread: Weak Spark
  1. #1
    Default Weak Spark
    Good Morning everyone,
    I have a 88 2.3L OMC Cobra that I have had an intermittent spark issue with. It did it with the cap and rotor and all new parts so I changed to electronic ignition, starter solenoid, all plugs and wires and new coil with the same problem.... it starts and runs and after about 4 minutes it dies and when we disconnected the coil wire from from the cap there is weak spark coming off the coil high tension lead.
    Can anyone direct me to what I need to do next?
    Also where is the resistor wire on this boat, I have been told different things. One person told me that its the purple wire off the assist solenoid and then another said its the purple wire that goes to the shift assist to bog the motor when going into gear.
    V
  2. #2
    Join Date
    Apr 2010
    Posts
    4,259
    Default Re: Weak Spark
    Edit....
Similar Threads
  1. 88 spl with weak spark
    By Hydro57 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-09-2014, 07:12 PM
  2. Weak spark
    By boatn4fun in forum Mercury Mariner Outboard Archive
    Last Post: 03-28-2009, 11:28 AM
  3. Weak spark
    By brian rhoades in forum Johnson Evinrude Outboard Archive
    Last Post: 02-09-2008, 10:34 AM
  4. No Spark on Starboard and weak intermittent spark on Port
    By 543svet in forum Volvo Penta Gas Archive
    Last Post: 06-22-2006, 06:51 PM
  5. Weak spark
    By ibnfshn in forum Archive 2003-2009
    Last Post: 05-04-2004, 06:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
