Click for Chrysler parts and manuals!
Results 1 to 4 of 4
Thread: coil
  1. #1
    Join Date
    Sep 2009
    Location
    Posts
    157
    Default coil
    crh 318 was converted to elec ing before I got it . having prob with coil cutting out . can take boat out runs fine 1/2 throt full throt. comeing in I have 15 min.ride up lagoon at idle .will cut out no spark oi red hot change coil starts right up at idle only batt voltage on plus side of coil some times 3.9 or 1.9 volts on neg side .cking coil on a crusader charge voltage in on plus. 6 volts out on neg. what is min voltage n neg side? ps have new cap rotor and wires thanks for any help
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,749
    Default Re: coil
    Is the coil getting hot? If so add a ballast resistor to coil posative and see how she runs?
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    784
    Default Re: coil
    We don't even know what your current ignition components are. Maybe you should list them and add a couple pictures.
  4. #4
    Join Date
    Sep 2009
    Location
    Posts
    157
    Default Re: coil
    sorry i havent gotten back sooner. did a lot more cking i had large voltage drops at the b+ spot on engine.we made new harness.to eng and back up to helm.voltages are good now coil gets as hot as eng temp because its bolted to it.thanks for trying to help
Similar Threads
  1. Tohatsu 2008 9.8HP coil infinite resistance in coil...
    By bushtor in forum Nissan Tohatsu Outboard Forum
    Last Post: 09-11-2016, 05:57 PM
  2. coil
    By missnancy in forum Crusader Marine Engine Forum
    Last Post: 06-13-2015, 03:17 PM
  3. Replies: 12
    Last Post: 08-20-2014, 05:37 AM
  4. coil wire from distributer ,,where does it go on coil +?-? plesase help
    By james luchi in forum Mercruiser Sterndrive Forum
    Last Post: 07-15-2013, 12:34 PM
  5. Coil ??
    By riopearl in forum Johnson Evinrude Outboard Forum
    Last Post: 08-09-2010, 07:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
