Results 1 to 16 of 16
  1. #1
    Default Oil brand and type
    Have a pair of 1985 Mercruiser 5.0L 305ci motors, what brand and type of oil do you use?
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    5,076
    Default Re: Oil brand and type
    Rotella diesel , 20W-50, 25W-40 Merc oil and a splash of Marvel Mystery Oil in the gas and oil
  3. #3
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    3,259
    Marvel Mystery Oil..... a blast from the past. My Dad's favorite.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
  4. #4
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    5,076
    It does work as intended, trust me.My F250 351 went a bit over 400K.
  5. #5
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,504
    I run Mobile One 15-50 Grey cap. 5 qrt jug at Walmart is ~ $25.00
    Napa Gold oil filter.
    Jack
    Mass.
  6. #6
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    1,777
    Straight 30wt in 5 gallon pails. Walmart has it in gallon jugs. Marine engines are more like industrial than transport engines. A heavy-duty lube like the 30wt is recommended by most marine manufacturers.
    Multi vis oils are overkill for marine engines since they typically do not operate in below-freezing conditions.
    Practicing the ancient art of ren-ching
  7. #7
    Before I posted this question I was planning to use this.... so it sounds like I should switch..???
    https://www.napaonline.com/en/p/NO_75115
  8. #8
    Join Date
    May 2010
    Location
    Posts
    1,777
    That will work but seems super expensive
  9. #9
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    16,675
    .."Multi vis oils are overkill for marine engines since they typically do not operate in below-freezing conditions"
    That has nothing to do with it! Every time a cold motor starts up the bearings take a beating until the oil pressure comes up. Using a 10W30 (for example) oil lessens that beating.
    Multi vis oils are a modern miracle of lubrication engineering. Why on earth would anyone still use straight weight oil from the 1930s?
    Jeff
  10. #10
    Join Date
    May 2010
    Location
    Posts
    1,777
    The only reason to use multi vis is to cover wide temperature conditions. The "W" is for "winter", not "weight". Your 10W-30 still behaves just like straight SAE30 in warm weather.
  11. #11
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    3,259
    Per a conversation I has with Andy Granatelli ( I bought an engine from him once).... multi weights for hydraulic liftered engines... "straight" for mechanicals...
    Capt Bob
  12. #12
    I had twin 1982 Merc 5.0. Manual called for marine 30w. Multi weight only if no straight weight was available. Upgrade to 5.7's last year. 5.0 were still kicking. I use Pennzoil and sometimes West Marine brand when on sale for $20.
  13. #13
    Join Date
    Sep 2003
    Location
    Posts
    16,675
    .."The only reason to use multi vis is to cover wide temperature conditions. "
    I believe I already covered that inaccuracy. Every time a motor fires up--with still no oil pressure--it needs a thinner oil to get things going.
    Jeff
  14. #14
    Join Date
    May 2010
    Location
    Posts
    1,777
    Ugh. Flat earthers.
  15. #15
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,504
    All I will say is use what ever you want as long as it meets Manufactures specifications.
    If in doubt, use their oil only and you wont have to ask this type of question.
    Mercs spec for almost all engines is 25w-40w standard non synthetic oil and a "tiny" oil filter.
    Yet they use synthetic gear oil now............go figure.
    Jack
    Mass.
  16. #16
    Join Date
    May 2010
    Location
    Posts
    1,777
    ^This^
Similar Threads
  1. best type/brand of Bolt extractor?
    By Beagleman in forum Mercury Mariner Outboard Forum
    Last Post: 09-15-2013, 12:03 AM
  2. Brand new 470 camshaft?
    By 1973 Browning Marine in forum Mercruiser Sterndrive Forum
    Last Post: 06-15-2010, 10:51 PM
  3. Brand new 3.0 overheat
    By captnbill in forum Mercruiser Sterndrive Forum
    Last Post: 05-02-2010, 09:35 AM
  4. Best Brand Starter
    By wickeral in forum Mercruiser Sterndrive Archive
    Last Post: 06-15-2009, 09:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
