Click for Volvo Penta parts and manuals!
Results 1 to 4 of 4
  1. #1
    Default AQ145A to a AQ170, good idea or no?
    Hello everyone, first post on the site and with all the good information I am finding I am hoping someone can help narrow down my search.
    I recently picked up a 17' Calglass with an AQ145a mounted to a 280 with hydraulic trim.
    The previous owner said that his mechanic had done a partial rebuild on it and found a cracked piston. I pulled out the boroscope to find out which one and low and behold piston 3 has a small crack. Compression test is within 15 psi between all 4 cylinders but haven't had the boat out on the water in fear i am missing something. I was expecting a drop in compression for #3 but there wasn't much.
    I am having trouble finding a new or replacement piston for this motor so I am thinking of doing a swap to an aq170.
    I can get the 170 motor with a 280 leg without trim for free. Motor runs great and the water pump was just recently rebuilt but has a leak between 3 and 4 which i have been told is the head gasket. The head gasket for the 170 is a lot easier to find then a piston for the 145
    My question is, is this engine swap a good idea? if not, then what should I do? if yes, then will the 170 bolt right on to my 280 leg, or do have to change out my whole set-up and install his engine and leg on my boat?
    Any and all help is appreciated.
    Thank you
    Eric
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,658
    Default Re: AQ145A to a AQ170, good idea or no?
    Do you have the room for a strait 6? You will need to put in forward engine mounts. Ricardo will know for sure but my guess is you just need to swap out the flywheel housing/PDS and the lower gearbox and just use your existing hydraulic trim. Free is always good wait for the experts to tell you if it is worth the money and effort.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    You know what, the very first thing you consider and it totally slipped my mind. I think your right.
    Thanks kimcrwbr1, looks like i'll be taking out the tape measure.
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,709
    Quote Originally Posted by EricJ View Post
    The 280 PT drives are few and far between these days.
    The previous owner said that his mechanic had done a partial rebuild on it and found a cracked piston. I pulled out the borescope to find out which one and low and behold piston 3 has a small crack.
    A partial rebuild..... yet the cracked piston was still down in the cylinder????
    I would take any of the seller's comments with a grain of salt only.
    Run, don't walk.
    Not that you need one right now..... but look up a price for a 170 exhaust manifold!
    NO!
    Find another Volvo Penta OHC 4 cylinder engine, or continue searching for pistons.
    The 170 can be made to work..... however, the lower gear unit will need to be changed to a 1.89:1 reduction. But again...... I would strongly encourage you to NOT DO THIS.
    Thank you
    Eric
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. Replies: 0
    Last Post: 07-28-2017, 06:34 PM
  2. Are Exhaust Tubes A Good Idea?
    By DavidW2009 in forum OMC Sterndrive and Inboard Forum
    Last Post: 09-14-2010, 08:30 AM
  3. Yamaha prop on Honda engine? Good idea?
    By sea_lion in forum Honda Outboard Forum
    Last Post: 05-16-2010, 12:12 PM
  4. Good idea to use synthetic motor oil
    By jtoma878 in forum Mercruiser Sterndrive Archive
    Last Post: 05-07-2009, 07:31 PM
  5. 87 force 125 forsale parts crank and 1 piston no good rest good Ldrive
    By Rickey mantzke in forum Chrysler Force Outboard Archive
    Last Post: 04-08-2004, 10:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
