Click for Chrysler parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default Chrysler 360 won't go over 3000 rpm
    While trying to solve my rpm issue I was looking at replacing the ecm, Since the engine is a 79 with 2000 hrs. I came across a part number #3874020. The description mentioned "rev limiter". Anybody heard of this and could the ecm have somehow reset 3000 rpm. Engine runs perfect but will not go over 3000. Used to go 4000.
  2. #2
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    768
    Default Re: Chrysler 360 won't go over 3000 rpm
    FWIW, #3874020 is a part number that was used on Chrysler autos as standard equipment from '76 through '79. These should be reliable up to 6000 rpm. I don't know of it having an internal "rev limiter" although one can be installed between the ECU and distributor.
    These units need to have the best possible grounding and should be kept away from excessive heat sources.
Similar Threads
  1. 3000 rpm is my max...
    By HotShot87 in forum Crusader Marine Engine Forum
    Last Post: 09-17-2012, 11:54 AM
  2. Max rpm 3000
    By bbluemarlin08 in forum Mercruiser Sterndrive Forum
    Last Post: 06-15-2010, 05:58 PM
  3. 94 Tohatsu 90A 3000 rpm max
    By wfshort in forum Nissan Tohatsu Outboard Forum
    Last Post: 10-10-2009, 08:16 PM
  4. 3000 rpm no more
    By madigrace in forum Suzuki Outboard Archive
    Last Post: 04-11-2009, 11:38 AM
  5. Sporadic RPMs above 3000 Chrysler 360
    By dbrahms in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 09-29-2008, 12:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
