Results 1 to 3 of 3
  1. #1
    Default 1990 130ETXD gasoline octane question.
    I have this old but great 130HP Yamaha 2 strokes. We are on vacation and the local marina only offers Regular gas with 10% Ethanol or Ethanol free high octane gasoline.
    At home, I have only used Ethanol free 87 octane with this motor. Any restriction on using High octane ?
    Thank you
  2. #2
    Default Re: 1990 130ETXD gasoline octane question.
    No. Just a waste of money is all. You will not get a performance boost from using a higher octane fuel, though it also will not hurt your engine. Same goes for only using a few tank fills of 10% ethanol.
    Everything you ever wanted to know about fuel can be read by following the link below. In regards to octane, read 6.13.
    http://www.turborick.com/gsxr1127/gasoline.html
  3. #3
    you can use a higher rating octane as it will not effect your engine performance however it will build up carbon in your combustion camber and other componets faster than lower rated octane but one use will not hurt
    now with that being said if you have an engine that is rated for 93 octane and you use 85 you will have alot of problems as it can cause pre ignition.
Similar Threads
  1. Gasoline additive question
    By fihlips in forum Yamaha Outboard Archive
    Last Post: 05-04-2009, 04:57 AM
  2. Gasoline Ethanol vs Rubber Hose Question
    By sailjumanji in forum Yamaha Outboard Archive
    Last Post: 04-12-2009, 09:35 PM
  3. Question about gasoline seperation
    By stevesnod in forum Johnson Evinrude Outboard Archive
    Last Post: 04-14-2008, 09:24 PM
  4. Gasoline question
    By davespades in forum OMC Sterndrive and Inboard Archive
    Last Post: 01-16-2008, 09:48 AM
  5. Does it matter if I run 87 octane or 92 octane gas
    By hsp in forum Johnson Evinrude Outboard Archive
    Last Post: 11-29-2006, 09:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
