Click for Volvo Penta parts and manuals!
Results 1 to 12 of 12
  1. #1
    Default starter was grinding now it won't turn flywheel
    I have a 1998 OMC Cobra with a Volvo Penta 5.7 260 hp Ran great till last month it made some noise on starting then it would only make grinding noise ,sometimes turning a little . I finally got to it and replaced the starter twice no difference . took it to a marina , they felt it was a problem with the flywheel and they didn't want to do the job. Took the boat home and built a frame and pulled the engine . the fly wheel looks ok ? no missing teeth , it will turn with the use of a 8 inch pry bar one or two teeth at a time . So I tested the starter on the engine the pinon shaft is to far from the flywheel and no matter how I shim it I get the same result - the starter gear comes out and fits into the flywheel then -loud click - it can't or won't turn the wheel . the gear doesn't return into starter after charge is removed until I pry the wheel a little bit. Sooo. whats up some bearing to tight -bad ? or is it locked up some how ? Help
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,817
    Default Re: starter was grinding now it won't turn flywheel
    Quote Originally Posted by Bigmac48 View Post
    OMC had long since been out of business by 1998 as a result of Volvo Penta having purchased the company back in 1994 or so.
    Be very careful........ you may break a tooth.
    You have an I/O boat, which means that your starter motor mounts in the standard and conventional automotive position.
    Shimming a SBC starter motor does not bring the pinion gear closer to, or further away from, the flywheel ring gear.
    Treat yourself to a new HTGR/PMGR starter motor and make dang sure that you get the correct bolts with it.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  3. #3
    Does the battery have enough charge?
  4. #4
    Join Date
    Apr 2013
    Location
    Lower Columbia River
    Posts
    100
    Have you tried the starter with the spark plugs removed?
  5. #5
    Tico -Yes two new batteries and all new cables but for the test with engine out used my car to try to start it
  6. #6
    DJR - that is tonights project at work now
  7. #7
    Ricardo Marine- will do if I don't have water in any of the cyclinders . I know the is none in the pan
  8. #8
    I just spent a 1/2 hour typing what I did and what my starter problem turned out to be and as i posted it I lost most of it so--
    I was wrong there was a lot of water in the engine . still not sure which problem -leaking heads, bad exhaust manifolds/risers or back flow but the engine is shot. with it's age I am going with a new one . Hydro lock in 40+ yrs of boating and 4 boats never knew it could happen by back flow .
    my question should have been [HOW MUCH WATER CAN MY ENGINE HOLD]
    Will try to let you know how I make out with the new one .
    Thanks to all who answered my post and also those in other posts , all of which I used to narrow down what I needed to do
  9. #9
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,817
    ...................... still not sure which problem -leaking heads, bad exhaust manifolds/risers or back flow but the engine is shot. with it's age I am going with a new one . Hydro lock in 40+ yrs of boating and 4 boats never knew it could happen by back flow .
    Before you install a fresh 5.7L SBC, find out what caused the problem in the first place....... exhaust manifold, etc?????
    If you re-use a part that may have caused this, you may have an expensive repeat!
    Portland, Oregon
  10. #10
    [QUOTE=RicardoMarine;582847]Before you install a fresh 5.7L SBC, find out what caused the problem in the first place....... exhaust manifold, etc?????
    I'm not using anything off the old engine but the power steering pump and alt. etc . I got new exhaust and risers coming and a new -5.&L( Enhanced Base ) Marine Engine Assembly-from Eagle Engine sales . But I am in the process of tearing down the old engine to find out why . I did learn that volvo penta sent out service bullitin that exhaust flaps were no longer needed and I don't have any on mine . Others said you just have to be careful how you drive
    thanks again rick -I do not want a repeat I will let you know what I find - it may take a while as we have a lake cottage and that where my wife wants to be and I took the boat home.
  11. #11
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,801
    You have to check the design of the exhaust elbows... For a while there, MERC ( and many aftermarket) exhaust elbows, had a design issue wherein "reversion", water back into the engine happened. See below.
    http://www.michel-christen.com/ExhaustElbows.pdf
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  12. #12
    Quote Originally Posted by sandkicker View Post
    Wow! Thanks for the link- there's a lot of info there
    my y pipe has the holes for the flapper but no flapper . and the elbows are not here yet to check the design .
    He talked about a resonator kit to correct the problem but as of now I have not found any for the OMC or volvo penta exhaust.
    still working on it thanks for the helpful info I understand more now
Similar Threads
  1. "83 40 hp 2 stroke rebuilt but starter will not turn flywheel.
    By equinton in forum Mercury Mariner Outboard Forum
    Last Post: 07-11-2016, 03:26 PM
  2. flywheel hard to turn
    By deep seadation in forum Yamaha Outboard Forum
    Last Post: 01-08-2012, 02:39 AM
  3. Starter grinding - 1999’ Volvo-Penta 5.7 GL 350 small block
    By doyouboat in forum Volvo Penta Gas Engine Forum
    Last Post: 08-26-2010, 10:52 AM
  4. Starter grinding
    By crzysamoan in forum Mercruiser Sterndrive Archive
    Last Post: 07-26-2009, 09:11 PM
  5. Johnson 90 starter grinding
    By mooseo in forum Johnson Evinrude Outboard Archive
    Last Post: 04-30-2004, 07:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
