Results 1 to 14 of 14
  1. #1
    Default Should my wheel bearing housing move like this?
    https://instagram.com/p/BXdqE0XgPrw/
    so should my wheel bearing housing move like this? The bearing went out on March and I replaced the seal and both bearings, and noticed my wheel was covered in grease again so I pulled it off and noticed this.. help pleas!
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,972
    Default Re: Should my wheel bearing housing move like this?
    Absolutely not. It looks like you might be missing the race either in the hub or on the spindle. Did you change those when you changed the bearings?
    CHawk 25 DLX
  3. #3
    I've got both races in the hub. I didn't see any race on the spindle. Is there supposed to be 3 races altogether? I thought it was just the two that go in the hub?
  4. #4
    There's some minor gouges on the spindle. But they aren't deep enough to make thehub move like it does
  5. #5
    Join Date
    Sep 2008
    Location
    Posts
    4,972
    Trailer axles are set up various ways. Some have a race that is pressed into the hub and the bearings inner race is integral to the bearing carrier and is pressed onto the spindle. Other bearing setups have a fully integrated bearing that has both the inner and outer race included and the whole bearing mechanism is pressed into the hub. You obviously have something wrong there. Are you absolutely sure you have the right size bearing? Did you make sure that the front and rear bearings (or races) were pressed into the hub completely until they hit the stopping ridge? Have you pulled the bearings and made sure it is in tact?
    CHawk 25 DLX
  6. #6
    So I've noticed that I am NOT capable of spinning the nut tight enough to where I can't spin the hub.. it will NOT tighten anymore. Which tells me the threads on the spindle are probably messed up.
  7. #7
    Join Date
    Sep 2008
    Location
    Posts
    4,972
    Or it tells you that you have the wrong bearing in there.
    CHawk 25 DLX
  8. #8
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
    Take your hubs up to your local U-haul and see if they will hook you up with the proper bearings and seals?
  9. #9
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
    If you trailer your boat long distances be sure and install bearing buddies that way you can shoot some grease in the hubs so they dont pull in water when you launch the boat. Just take a grease gun with you if you submerge the hot hubs in cold water they cool quickly and create a vacuum pulling in water through the seals.
    EDIT do both wheels at the same time that way you can use the other side to get the proper parts.
  10. #10
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
  11. #11
    I have the exact same bearings as the other side , and the other side is good. I pulled
    the driver side off to see if I was missing anything. And Kim I have bearing buddies, I just hadn't put it back on when I took this video.
  12. #12
    Just to inform y'all we got it fixed today! Where the outer bearing sits on the spindle had some grooves where the bearing had failed back in March, thus I couldn't tighten the nut up anymore We got some Emory cloth and went over it for a couple minutes and got the bearing to sit right again. It wasn't much. It wasn't off even a 1/10 of an inch. Got a new nut put on and filed the threads on the spindle back. Tightened her down and not any movement from the hub at all!
  13. #13
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
    Did you back of 1/4 turn loose on the nut after getting it tight? The proper way is to jack the tire up and tighten the nut until the tire will not spin free. Loosen the nut 1/4 turn and then install the keeper and cotter pin. Then install the bearing buddy and pump it with grease until the grease pushes slightly out on the center of the bearing buddy.
  14. #14
    Yes it spins freely after loosening a 1/4 turn. And then I put the keeper on the nut and the cotter pin and then the bearing buddy and pumped it full of grease.
Similar Threads
  1. Can't move water pump housing cover up drive shaft.
    By wassajet in forum Mercury Mariner Outboard Forum
    Last Post: 11-13-2013, 06:15 AM
  2. Aligning steering wheel...how to move the shaft with the wood-ruff key slot
    By FRD1952 in forum Boat Steering and Engine Controls
    Last Post: 08-16-2013, 07:21 PM
  3. Flywheel housing has no way to grease PDS bearing. What to do?
    By Rattlin S in forum Volvo Penta Gas Engine Forum
    Last Post: 06-23-2013, 07:52 AM
  4. wheel bearing buddys
    By pudsy01 in forum Miscellaneous marine engine topics
    Last Post: 08-26-2010, 05:57 PM
  5. Trailer wheel bearing
    By terrapin24h in forum Mercruiser Sterndrive Archive
    Last Post: 06-18-2008, 03:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
