Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 6 of 6
  1. #1
    Exclamation DT 9.9 charging system?
    just picked up a 9.9 Suzuki tiller today. question is was told It had a charging system well it would be cool if it did but I'm also thinking the plug wires are on the wrong cylinder, seems to be quite jumpy. does anyone have a wiring diagram and a cylinder and plug wire diagram? I also don't know a year was told a 91 the tag on the clamp is as follows Suzuki dt9.9 0991 002821
  2. #2
    Default Re: DT 9.9 charging system?
    probably would not even run if the spark plug wires were reversed.
  3. #3
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    113
    You have a 1980 model .... have a look at the parts diagram here ..... http://www.brownspoint.com/store/pc/...T16(80-82).pdf
  4. #4
    YeAh I'm now trying to get a service manual for it to figure out how to set the carb
  5. #5
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    113
    Carb setting is easy, but are you talking about the linkage or the air/fuel? Air/Fuel setting is ..... 1 & 1/2 turns outwards from soft stop ....
  6. #6
    Quote Originally Posted by deejaycee_2000 View Post
    Ya believe my fuel pump is not working properly motor is really choppy and won't run at wot don't matter where air/fuel is at
Similar Threads
  1. charging system ?
    By ROGMOR in forum Johnson Evinrude Outboard Forum
    Last Post: 08-22-2012, 11:42 PM
  2. 88 charging system
    By west500 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-07-2011, 08:36 AM
  3. Charging system
    By sidebottom in forum Chrysler Force Outboard Archive
    Last Post: 06-20-2008, 01:57 PM
  4. Charging System
    By jrisebo in forum Volvo Penta Gas Archive
    Last Post: 06-16-2008, 01:05 PM
  5. Charging System Not Charging
    By donnella in forum Archive 2002-2006
    Last Post: 08-17-2003, 11:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
