Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2017
    Location
    *******n, Idaho
    Posts
    3
    Question 73 Crestliner 17' 165HP Stringer GM250 I6 motor. Are my motor mount attachments bent?
    Hi. First time here. Hoping someone can tell me if I'm on the right track or not. I recently bought this boat that's been sitting for 5 years. Got the motor running, but the tilt and trim motors were not working. Replaced the tilt motor and think that's good now. Still need to replace the trim motor. Transom seal bellows were sort of attached with some crappy silicone so I removed it to get to the tilt motor easier and to seal it better. Transom wood seems solid so that's a plus. When I tried to put the bellows back on, it doesn't want to stretch high enough to reach the screw holes. It seems like there is a much bigger gap above the intermediate housing than below it. I figured I would undo the selectrim tilt system which is frozen in place and see if I could lower the front of the motor a bit. When I removed the selectrim mount in the front, I found that the pulley on the motor has been rubbing against it and they were wearing each other away. I don't think this should be possible if the motor mounts are in the right place. I can see that the attachment at the top of the selectrim is not in line with the center of the motor mounts but is more toward the bow. This makes me wonder if it's possible that someone backed the outdrive into something and pushed the whole motor forward of where it should be by a couple of inches. The motor mounts at the rear seem to confirm my theory as they appear to be tilted forward instead of being level. I don't know if I'm explaining it well so I created a short video and put it on Youtube here if you want to take a look. Hope that's ok to do here. https://youtu.be/aw3jOwy7Thg. My question is, are the rear mounts supposed to be like this or are they bent, and does anyone have a suggestion on how to fix it without having to remove the whole motor? Thanks a bunch.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Join Date
    Aug 2017
    Location
    *******n, Idaho
    Posts
    3
    Default Re: 73 Crestliner 17' 165HP Stringer GM250 I6 motor. Are my motor mount attachments bent?
    Adding more pics
Name:	wear on selectrim mount.jpg
ID:	16144Click image for larger version.
Name:	wear on crank pulley.jpg
ID:	16145Click image for larger version.
ID:	16140Click image for larger version.
ID:	16141Click image for larger version.
ID:	16142Click image for larger version.
  3. #3
    Join Date
    Aug 2017
    Location
    *******n, Idaho
    Posts
    3
    Attachment 16146One more pic showing how the motor seems to sit low in the opening on the stern.
Similar Threads
  1. What trolling motor for my 18' Crestliner Phantom
    By Dan Moeller in forum Minn Kota Trolling Motors Forum
    Last Post: 01-28-2015, 04:38 PM
  2. Replies: 3
    Last Post: 08-10-2014, 06:16 AM
  3. 1975 johnson motor lower motor mount removal 40hp
    By HAWK1450 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-03-2011, 03:37 PM
  4. 165hp I4 is the infamous 37l Merc 470 motor
    By alex5215 in forum Mercruiser Sterndrive Archive
    Last Post: 03-16-2009, 08:53 AM
  5. 15 hp Johnson transom mount problems Below engine motor mount
    By Ronnie Hubenk in forum Johnson Evinrude Outboard Archive
    Last Post: 04-17-2004, 03:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
