Click for Crusader parts and manuals!
Results 1 to 3 of 3
  1. #1
    Default 2007 8.1 hunting
    I have a 2007 Crusader 8.1. The motor starts to hunt at about 900-1000 rpm after reaching operation temperature. And then loads up and stalls. Anything below 900rpm and above 1000 rpm it's fine. I used a scan tool and no codes are coming up. Any help would be appreciated.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,310
    Default Re: 2007 8.1 hunting
    most ECU's only turn on the light (set a DTC) when a sensor is 'bad' where bad means out of range....the delphi example is an ECT that is ~ 50 degrees off but still in a "legitimate" range. so you need to verify the sensors' outputs with the scan tool....
    The other thing is that the ECU doesn't monitor everything, and the list of what it does check varies with the ECU/model year - newer ones do more than older ones....so a problem may occur w/o and DTC....
    I'd be inclined to start by removing the IAC unit and cleaning it.....10 years of time would be a decent service interval....
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,310
    turns out there's no IAC on that engine.....suggest you do a www search on "crusader" and "ECM-07" you should find a pdf file that will explain most of the controls used....there are several areas that cover 'surging' idle....
Similar Threads
  1. Hunting at idle
    By tyson1 in forum Volvo Penta Gas Engine Forum
    Last Post: 10-10-2013, 09:34 AM
  2. wandering and hunting
    By SYDMAR in forum Volvo Penta Gas Engine Forum
    Last Post: 08-15-2013, 12:51 PM
  3. BF9.9 RPM's hunting while trolling.
    By triplenickel in forum Honda Outboard Forum
    Last Post: 06-12-2012, 12:01 PM
  4. Hunting engine
    By pidde in forum Volvo Penta Gas Engine Forum
    Last Post: 08-19-2009, 04:43 PM
  5. VP 2003 hunting
    By crzhors in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 04-09-2008, 05:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
