Results 1 to 4 of 4
  1. #1
    Default Can I use velvet drive 72c with a Chrysler 318?
    Hi guys. The original box was a 71c. I can't find much information on this. I was able to score a pair of good transmissions which were advertised as 71cs but got them home and had a look and turns out they are 72s. Any help will be greatly appreciated.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,399
    Default Re: Can I use velvet drive 72c with a Chrysler 318?
    its usually easier (and less ambiguous) to refer to the model numbers to ID the gears in question.
    The 72's will bolt up to the same bell housing as a 71....the dampers are usually different but only in spring tension I believe...if the original ones have any time on them it'd be good to change them too.
    The catch is that the 72's are a bit longer....so "will it fit" depends upon how close the stuffing box is.....best to measure it. and remember you need some 'extra space' to split the couplings....
  3. #3
    Thanks for the info Makomark. So it is less confusing to refer to them as 1017 and 1018 velvet drives? I am replacing engines too so I can slide them up to accommodate that little extra length. The 1018 will work with my 318s then even though they are designed for higher horsepower? The documentation is confusing. The flange is 5" on the 1018 where the 1017's are 4" so I will have to find a coupler to connect the prop.
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,399
    putting a higher rated gear in place of a lower rated gear will work fine - the other way usually doesn't....
    AIf you move the engines forward, the bed may need to be raised (shimmed) as well - depends upon the hull.
    getting a new coupler for your shaft isn't hard; its just $$$....
    You may want to visit a good local gear shop - they can probably give you other pointers as well.
Similar Threads
  1. velvet drive 71C
    By philcapper in forum Marine Transmissions and Reverse Gears
    Last Post: 01-18-2013, 04:24 PM
  2. Replies: 0
    Last Post: 07-08-2012, 05:51 PM
  3. Borg Warner Velvet Drive has play in drive
    By rwerner43 in forum Miscellaneous marine engine topics
    Last Post: 06-03-2011, 02:30 PM
  4. 1987 Dixie 299 351 velvet drive drive line question
    By romans116 in forum Pleasurecraft Marine PCM Forum
    Last Post: 03-22-2008, 09:44 PM
  5. Velvet drive
    By scott walters in forum Archive 2002-2006
    Last Post: 09-06-2000, 12:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
