Results 1 to 3 of 3
  1. #1
    Default 1971 6hp 6102G outboard
    Just hot a 71 6hp outboard motor. The number on engine is 6102G. Wonder if i need to mix the gas? If so whats the ratio and the best mixture? Thank you
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,884
    Default Re: 1971 6hp 6102G outboard
    Mix the fuel at 50:1 with a high quality TCW3 grade two stroke oil. 1971 evinrude 6hp. Be sure and change the impeller if you do not know how old it is and change the gearoil with a outboard specific gearoil.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,884
Similar Threads
  1. 1971 Evinrude Outboard 50 HP
    By StarterBoat in forum Fuel / Oil Mixture Ratio
    Last Post: 08-12-2014, 11:44 PM
  2. 1971 evinrude outboard
    By iwalkonwater in forum Johnson Evinrude Outboard Forum
    Last Post: 09-05-2012, 10:26 PM
  3. 1971 6hp 6102G Evinrude Outboard motor
    By johnfspring in forum Johnson Evinrude Outboard Forum
    Last Post: 07-22-2011, 08:53 PM
  4. 1971 Chrysler outboard 55 hp
    By eaglepacker in forum Chrysler Force Outboard Archive
    Last Post: 08-01-2007, 09:40 PM
  5. 1971 Chrysler outboard 55 hp
    By Mary Meisner in forum Chrysler Force Outboard Archive
    Last Post: 05-21-2006, 10:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
