Results 1 to 3 of 3
  1. #1
    Default Need The right Flywheel for GM502 ci, 338HP
    Common 502 GM block, 8.2L engine
    Hello,
    i use on my Jetboat a 502 GM engine with HJ212 Pump.
    I have to change the Flywheel 14096805 and got a new one. Both have the selm castin P/N but the gear ring is on the another side of the flywheel.
    Sombody know the right Part # and where i can get this?
    Regards
    Walter
ID:	16076 Click image for larger version.
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,445
    Default Re: Need The right Flywheel for GM502 ci, 338HP
    Ayuh,.... Knock the ring gear off, heat it up, 'n drop it onto the other side,....
  3. #3
    The new Flywheel have a schoulder, this dont work
Similar Threads
  1. flywheel key?
    By shawnfish in forum Johnson Evinrude Outboard Forum
    Last Post: 07-16-2012, 10:54 AM
  2. How to hold flywheel to remove flywheel nut??
    By Bill K in forum Mercury Mariner Outboard Forum
    Last Post: 07-29-2011, 04:07 PM
  3. Flywheel
    By johnm in forum Mercruiser Sterndrive Forum
    Last Post: 10-18-2009, 08:38 PM
  4. 25A Flywheel
    By knotdreamin in forum Honda Outboard Archive
    Last Post: 07-08-2008, 04:26 PM
  5. 91 dt 40 flywheel
    By hintingsonny in forum Suzuki Outboard Archive
    Last Post: 06-06-2007, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
