Results 1 to 8 of 8
  1. #1
    Default Yamaha 40TLRZ 2 stroke - rebuilt carbs idles great but no longer get high RPM
    Hello everybody, first time poster here. Thanks in advance for any advice.
    I have a 1999 or 2000 Yamaha 40TLRZ (low hours, I can get maybe 10-20 hours on the water a year). I recently had to rebuild the carburetors, middle one was full of crystalline stuff (salt?) anyhow - new floats, new float valves, needles, valve seats, seals etc. Also replaced the fuel pump and made sure the fuel filter was clean (did not replace).
    Engine started like a dream. Adjusted needles for fastest idle (around one turn open or so). And off we went. But ran great for about a half an hour planning at high speed going to our favorite fishing spot. Bluefish hitting the surface, casting and able to bring one aboard, then off to the place where my brother can spear fish and I'm telling him "come on let's go!" and he says he's got the throttle full on. (travelling at a fast idle at this point with motor sounding like it was bogging). In fact the vent on the gas tank was closed. I opened it. Still no joy.
    I powered off. Took of the hood, checked throttle linkage - seems well adjusted (made sure this was the case before hand). Manually manipulated the butterfly linkage and saw all was moving as it should. Timing adjustment moves from idle point to high RPM point just fine as it is supposed to.
    I then started it up, moved the idle speed to fast, motor revved up fine, then put the motor in gear and moved the throttle forward and it sort of punched up a couple of times (zing.. zing..) and up we went to full speed. So I thought the engine must have sucked itself into some kind of locked closed situation when the vent was closed. We motored back home after landing a striper and a blue, and then again, after a half hour at high speed. Slowed down, then tried to speed up and it bogged down again! Could not get it to go fast anymore. Moved the throttle to full on and every once in a while a zing up to full RPM for a fraction of a second, but no more.
    Seems like a fuel issue. If anybody has seen this before, would be much obliged for your guidance.
    Again thanks in advance.
    Jerry
  2. #2
    Join Date
    Jul 2017
    Location
    Florida
    Posts
    17
    Default Re: Yamaha 40TLRZ 2 stroke - rebuilt carbs idles great but no longer get high RPM
    Oh also, before we put it in the water we also replaced the impeller.
    When the throttle cable gave out I wasn't even touching it which is interesting to me. We just made it out of deeper water and I could see it was a bit shallower but I highly doubt we hit anything. Maybe sucked something up and its still there? Engine still spits out water but could it be partly clogged causing a lack of power?
  3. #3
    Join Date
    Jul 2017
    Location
    Florida
    Posts
    17
    I've flushed the engine with a hose after every use since I'm on saltwater. When connecting with that hose adapter is shoots the water through quite strong so that doesn't seem clogged at that point. Maybe clogged down lower?
    (Forgive my ignorance, I'm learning)
  4. #4
    Quote Originally Posted by schreck425 View Post
    You are in the wrong thread. This is my thread!
  5. #5
    Join Date
    Jul 2017
    Location
    Florida
    Posts
    17
    Ugh... my bad!!!
  6. #6
    Quote Originally Posted by jkorten View Post
    Jerry
    Any chance water had got into fuel tank? Old fuel, or often replaced? Did you notice what the status of the primer bulb was during the time the engine was bogging down?..collapsed, full, normal?
    When you cleaned the carbs, did you also pull jets from each carb and clear each of debris?
  7. #7
    Quote Originally Posted by ClassicAQ View Post
    Thank you - Perhaps a chance. I temporarily bypassed my water filter before rebuilding the carbs, perhaps I put this back in. Primer bulb was stiff. Indeed I did replace the jets and there was a brass insert (the jet seat) that I also pulled and replaced with new O-rings below.
    But I will put the water filter back in line and swap out the gas tank thanks for the suggestion.
    Jerry
  8. #8
    Jerry
    So an update - the engine mostly will work at high RPM but occasionally I go through this phase where you advance the throttle full on, the engine goes brrrrr at a low RPM and suddently VROOOM then brrrrr then VROOOM then brrrr. Switching between the two RPM way to fast to be a fuel issue. Seems electrical. Do I just replace the solid state ignition module and spark plug wiring harness?
    Jerry
Similar Threads
  1. Suzuki 25 2v 4 stroke idles great will not run
    By fire_capt_al in forum Suzuki Outboard Archive
    Last Post: 03-16-2009, 05:25 PM
  2. Tohatsu 8hp 2 stroke The motor idles great accelerates horribly
    By scottsoutboards in forum Nissan Tohatsu Outboard Archive
    Last Post: 11-30-2008, 02:07 AM
  3. Classic 50 idles great no high drive
    By Mike Ammons in forum Mercury Mariner Outboard Archive
    Last Post: 07-13-2008, 10:54 PM
  4. Yamaha 70hp idles great misses on acceleration
    By sucker_dave in forum Yamaha Outboard Archive
    Last Post: 07-26-2007, 12:11 AM
  5. Replies: 1
    Last Post: 06-23-2003, 03:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
