Results 1 to 3 of 3
  1. #1
    Default #2 cylinder not firing
    1997 200hp Johnson.Top #2 port cylinder not firing the other five are ok. Compression good, mechanic has changed coil, power pack,timer base and stator can not find problem. Any suggesstions would help.
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,865
    Default Re: #2 cylinder not firing
    Is there spark on # 2 that will fire a gap of 3/8" , yes or no ?-----Or no change in operation when you pull # 2 wire off the plug ?-----Checked into possible crankcase compression issues ?
  3. #3
    Racerone,
    Has proper compression, #2 plug not firing at all
Similar Threads
  1. 1978 115 hp 6 cylinder Number 5 and 6 cylinder are not firing or very little spark.
    By i1bowhunter in forum Mercury Mariner Outboard Forum
    Last Post: 07-05-2015, 08:37 PM
  2. Cylinder not firing
    By fleabit in forum Yamaha Outboard Forum
    Last Post: 02-04-2012, 05:24 PM
  3. One cylinder not firing
    By astro601 in forum Mercury Mariner Outboard Archive
    Last Post: 09-20-2008, 04:35 PM
  4. #3 cylinder not firing
    By bammer in forum Johnson Evinrude Outboard Archive
    Last Post: 09-08-2006, 06:11 PM
  5. Cylinder not firing
    By salmonkiller01 in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-23-2006, 09:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
