MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default Need info on a Mercury 110 Thunderbolt Ignition
    I recently purchased a boat with a Mercury 110 Thunderbolt Ignition outboard and I'm having issues keeping it running. I'm pretty sure the carb needs to be adjusted and that's it, but I figure if Im going to open it up I might as well rebuild the carb, change the plugs, and replace anything else that looks worn. This is the first motor I've ever worked on, but seems to be a good one to start on. I need to know the year it was made before I go out and buy a bunch of parts for it. The serial number is 7093687. Any help would be greatly appreciated.
  2. #2
    Default Re: Need info on a Mercury 110 Thunderbolt Ignition
    Also I should add I am in Canada and I believe that may cause the serial number to be different. No idea if the motor was made in Canada or not.
  3. #3
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    That is a Canadian serial (production) number from about 1977 (the records are a little sketchy).
    It would have been built in Mississauga Ontario which was Merc Canada while it was in business.
    Most online parts lists that you can access give US serial ranges. In this case you can use 4605112 which would be "mechanically identical".
    Now trying to get parts from a Merc dealer for a motor of that vintage may be challenging at best.
    For parts reference, this sites page for that model is here: http://www.marineengine.com/parts/me...ru-4839253-usa
    A quick look shows more "no longer available" than anything else so you may have to go to a specialized dealer of more vintage parts. I live in Eastern Ontario and one of my "go to" parts source places is Laing's Outboards (they are in the Buffalo NY area). They will mail order up here no problem and they have a decent supply of vintage parts (I get parts from them for my own 1961 Gale (OMC) outboard).
    So if you can't source what you need from the limited parts still available from Merc (or Sierra - an aftermarket seller), then Laing's may be able to help you out.
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  4. #4
    Quote Originally Posted by galamb View Post
    Very helpful. Thank you!
Similar Threads
  1. mercury 200 20HP thunderbolt ignition
    By paul1972 in forum Identifying Model / Year / Horsepower
    Last Post: 05-05-2014, 05:47 AM
  2. Mercury 50 hp thunderbolt ignition
    By Tommyk74 in forum Mercury Mariner Outboard Forum
    Last Post: 09-03-2013, 07:11 AM
  3. Mercury 20hp 200 Thunderbolt Ignition
    By Kraftsman in forum Mercury Mariner Outboard Forum
    Last Post: 03-30-2011, 03:25 AM
  4. 74 mercury 115 HP thunderbolt ignition 6 cyl
    By marvel in forum Mercury Mariner Outboard Archive
    Last Post: 08-25-2006, 01:05 PM
  5. Thunderbolt ignition mercury 115rotor help
    By limige in forum Mercury Mariner Outboard Archive
    Last Post: 04-11-2006, 03:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
