waterboy76
Hello to all, I got a 1975 Johnson 70 hp. I bough the boat from someone and here is the problem. Motor start great, idle great, and runs great off water hose, in the water it die as soon i put it in gear, sometimes does not die and runs but no power. Compression test is 145/125/125. Here is what i found, #1 and #2 cylinder/coil is working, #3 is not but it has spark. I switched coils and they are good because they work on every cylinder except the #3, but again #3 has spark, but when I take the plug wire on and off the spark plug it doesn't do nothing. I search on youtube how to test the stator and seem that mine is good, it show 650 in ohms. Coils are good, so powerpack?? can a powerpack send signal to the coil and still be bad? HELP please.
