Results 1 to 6 of 6
  1. #1
    Join Date
    Jun 2017
    Location
    Ontario as well
    Posts
    58
    Default 18 HP 1970 Fastwin pushing 14 foot Tin boat
    My prop is a little banged up, so looking for a new one. Is their an ideal prop for this combo in your opinion? The boat will usually have no more than two people in it.
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,875
    Default Re: 18 HP 1970 Fastwin pushing 14 foot Tin boat
    What is the pitch on the prop you have? Ideally you want to achieve proper WOT rpm with the boat loaded.
    http://www.ebay.com/itm/Michigan-Mat...ZR9wt7&vxp=mtr
    A 10 pitch should be good for a 14ft skiff.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,875
    Quote Originally Posted by kimcrwbr1 View Post
    This says mariner but it is a OMC part number 012011
  4. #4
    Join Date
    Jun 2017
    Location
    Ontario as well
    Posts
    58
    Not sure what the standard pitch is. I will have a look at the motor over the weekend. Is there usually a number written on the prop? I believe it to be the original one the motor came with.
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,875
    There should be a part number it is either 9 or 10 inch pitch I am pretty sure.
  6. #6
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,875
    If it is a stock prop it should be marked on the flat part under the cone.
Similar Threads
  1. 18 HP 1959 Fastwin starter bracket on 1970 fastwin??
    By Nucad in forum Johnson Evinrude Outboard Forum
    Last Post: 07-20-2017, 05:52 PM
  2. 1970 Merc 500 Thunderbolt on a 15 foot Mirrocraft. What pitch prop?
    By Roadblock in forum Mercury Mariner Outboard Forum
    Last Post: 08-07-2014, 10:08 AM
  3. Cost of operating a 115 foot motor boat
    By magdaline115 in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 02-02-2007, 10:18 PM
  4. Big foot 50 hp 4 stroke for a 17 foot aluminium boat
    By mario in forum Archive 2003-2009
    Last Post: 07-07-2003, 11:39 AM
  5. Springbok 17 foot fishing boat
    By mario in forum Outboard motors archive 2000-2004
    Last Post: 12-12-2002, 11:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
