Results 1 to 4 of 4
  1. #1
    Default Omc 175hp electric shift lower swap compatibility
    Hello,
    i have a question that pertains to the gears in a 175hp stringer lower unit..it's mated up with a 5.0 ford in a 1977 reinell cuddy,
    my cavitation plate is broken off on the on side of my lower unit and this has been causing me to have problems getting up on plane. I found a lower that came from a v6, it's the exact same profile and size of my 175 outdrive, but it's from a V6. Anyone know if I could swap just the lower units out without causing myself any other issues? Or would I need to swap out all the gears and etc to the lower unit that has its cavitation plate in tact?
    Any help would be greatly appreciated and thank you, Jason
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,149
    Default Re: Omc 175hp electric shift lower swap compatibility
    As far as I know the lowers are all the same.---Gear ratio changes were in the upper gear box.
  3. #3
    Awesome... thank you for the info on that��
    that should be an easy swap then���� If the shift cable on this other unit happens to be frayed, can I butt connect the wires and heat shrink? And what kind of grease should I use on the gearshift splines?
  4. #4
    You can
Similar Threads
  1. lower unit of 1972 50 hp Johnson hydro electric shift
    By riles1967 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-13-2016, 03:11 PM
  2. Replies: 2
    Last Post: 09-25-2014, 06:48 PM
  3. lower unit compatibility
    By cassi in forum Johnson Evinrude Outboard Forum
    Last Post: 05-06-2012, 03:10 PM
  4. Lower unit compatibility Help
    By Chris Neiman in forum Mercury Mariner Outboard Archive
    Last Post: 05-02-2006, 10:36 AM
  5. Helpneed lower parts62 75hp evinrude electric shift
    By hideaway in forum Johnson Evinrude Outboard Archive
    Last Post: 06-21-2003, 01:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
