Results 1 to 7 of 7
  1. #1
    Default piston replacement on 1977 85 hp evinrude 85793s
    do I have to pull the powerhead in order to remove the pistons
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,944
    Default Re: piston replacement on 1977 85 hp evinrude 85793s
    Yes, the engine has to be removed from the exhaust housing to do a proper job.
  3. #3
    Quote Originally Posted by racerone View Post
    thank you
  4. #4
    should I purchase a rebuild kit
  5. #5
    or should I get each part from marine engine as they do not sell kits of this kind
  6. #6
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,944
    Take it apart first.------Then inspect and plan the repairs.
  7. #7
    thanks for all of your help I have four boats and love doing as much of the work myself as I can however this will be my first rebuild other than being a parts cleaner for my dad
Similar Threads
  1. Piston Failure 1977 Evinrude 15HP
    By JJGulley in forum Johnson Evinrude Outboard Forum
    Last Post: 05-27-2017, 05:12 PM
  2. 1977 115HP Piston Ring Locating Pin Acceptable Length
    By nicklanigan in forum Johnson Evinrude Outboard Forum
    Last Post: 02-12-2017, 11:12 AM
  3. Piston Pitting 25 HP 1977 Evinrude
    By bill VV in forum Johnson Evinrude Outboard Forum
    Last Post: 04-21-2014, 12:57 PM
  4. Evinrude 85HP 85793S
    By tony_sedona in forum Johnson Evinrude Outboard Archive
    Last Post: 08-18-2009, 09:41 PM
  5. Piston ring gap on a 1977 140hp johnson
    By danny in forum Johnson Evinrude Outboard Archive
    Last Post: 04-20-2004, 10:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
