Results 1 to 3 of 3
    Default 5.5 Johnson fuel mixture
    I have a 5.5 Johnson(CD-21a) and I'm looking for the oil mixture. I was told from the guy I got it from that it's 50/1 but then I've looked around and found both 50/1 and 24/1. Does how can I find out for sure what I need in it?
    Sep 2010
    ontario
    13,960
    Default Re: 5.5 Johnson fuel mixture
    That is a 1964 model.----Now 1964 was the first " official " year that Johnson / Evinrude ran on 50:1 mix.-----But oil / lubrication on 2 strokes is not well understood so you may get a lot of different opinions.-------------That is a well engineered little motor .---They run very, very nice and with proper care will last another 50 years.-------I had one of those apart last winter.----A low hrs motor that will run like new again !
    Yeah I put a new head gasket, exhaust gasket, thermostat, lower end seals, impeller/impeller housing and a few other odds and ends, just took it out and it ran great! Smoked a lot at first but once it warmed up it ran fantastic! Thank you for the information!
  1. 1960 Johnson 40 HP, recommended fuel octane and fuel mixture
    By LymanJohnson in forum Johnson Evinrude Outboard Forum
    Last Post: 10-08-2015, 08:46 PM
  2. Oil Fuel Mixture for 1988 Johnson 15 HP
    By purryburry in forum Fuel / Oil Mixture Ratio
    Last Post: 11-09-2010, 06:42 AM
  3. Fuel mixture b71 johnson
    By mhorsmon in forum Johnson Evinrude Outboard Archive
    Last Post: 12-28-2007, 12:30 AM
  4. 58 Johnson Fuel Mixture
    By burroak1 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-05-2007, 11:45 AM
  5. Fuel mixture for 1950 johnson 5 hp
    By buster in forum Johnson Evinrude Outboard Archive
    Last Post: 04-16-2004, 08:07 AM
