MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
  1. #1
    Question 2002 Mercury 4-Stroke 40Hp Motor w/Steel Prop & Sq-Lok Hub System -Prop Nut Torque Help
    I have a 2002 Mercury 4-stroke 40hp motor with a Stiletto steel prop. It has a Guardian SQ-Lok hub system. The hub system is made of nylon with a brass spline. The prop nut spacer is also nylon. The instructions for the hub system says to tighten the prop nut to the specs in the motor's manual which is 55 ft/lbs. When I tried to do this it crushed the prop nut spacer. I had to buy a new hub system to get another prop nut spacer.
    What should I torque the prop nut to? Should I just tighten the nut as tight as I can without crushing the spacer & secure the prop nut with the tab washer?
    This link goes to the hub system. It is MAR-C011H-UB-00. http://bblades.com/shop/hub-kits/tur...cury-4-stroke/
  2. #2
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    133
    Default Re: 2002 Mercury 4-Stroke 40Hp Motor w/Steel Prop & Sq-Lok Hub System -Prop Nut Torque Help
    The prop nut should be tightened by hand and then only a 1/2 a turn from there with a spanner, it should not be torqued but rather lightly tight.
Similar Threads
  1. 2002 Mercury 40hp /prop movement?
    By Howmaster in forum Mercury Mariner Outboard Forum
    Last Post: 01-03-2017, 02:37 PM
  2. Prop nut torque, 2000 Yamha 40hp
    By Matsuri in forum Yamaha Outboard Forum
    Last Post: 10-05-2010, 04:58 AM
  3. Mercury Prop Torque Tube
    By Dave Windsor in forum Mercury Mariner Outboard Archive
    Last Post: 04-30-2008, 10:07 PM
  4. Is it stainless steel or not mercury prop
    By Mike Blackstone in forum Mercury Mariner Outboard Archive
    Last Post: 03-06-2006, 06:11 PM
  5. Stainless Steel Prop for 2002 15hp Mercury Outboard
    By Gene Marsh in forum Mercury Mariner Outboard Archive
    Last Post: 03-06-2006, 05:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
