Results 1 to 5 of 5
  1. #1
    Default 115 evinrude stalls at low rpm
    I got a late 70's 115 about a month ago. I put it in at the boat ramp and ran it to my dock. It worked pretty well and shifted nicely ,though I thought it was at a high rpm(no tach, just past experience) for shifting. It shifted smoothly into all 3 gears so I am not worried. The next time I tried to run the motor I had a fuel problem which at least partially turned out to be the check valve in the tank. With this fixed, I can start the engine at warmup throttle, but if I try to throttle down, it stalls. What steps should I take?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: 115 evinrude stalls at low rpm
    Check compression , and check spark on all 4 leads.------Could be running on 3 cylinders.
  3. #3
    I have spark on all four, so I will do a compression test. Thanks!
  4. #4
    My compression test was 130 on both top cylinders and 130 on both bottom, so changing the fuel pump is what I'm doing next.
  5. #5
    I just realized I said 130 on bottom. They were 120
Similar Threads
  1. 1973 65 hp evinrude stalls
    By cliffnuce in forum Johnson Evinrude Outboard Forum
    Last Post: 08-29-2014, 08:23 AM
  2. Evinrude 8 HP 1991 Stalls on low RPM
    By Mike_swe in forum Johnson Evinrude Outboard Forum
    Last Post: 07-22-2013, 06:50 AM
  3. b98 Evinrude 150 stalls while trolling
    By jemmie in forum Johnson Evinrude Outboard Archive
    Last Post: 11-30-2009, 12:43 PM
  4. Evinrude 99 1992 stalls
    By aleksanm in forum Johnson Evinrude Outboard Archive
    Last Post: 10-03-2007, 03:58 PM
  5. b87 evinrude 60 stalls
    By dreamchaser in forum Johnson Evinrude Outboard Archive
    Last Post: 07-14-2007, 12:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
