Click for Chrysler parts and manuals!
Results 1 to 11 of 11
  1. #1
    Exclamation Chris Craft Cavalier with V8 Big Block to identify
    Dear all,
    I own a Chris Craft with a Chrysler V8 big block and I would like to find some doc about it but first I have to identify it so I need your help!
    Thanks in advance!!
ID:	15986Click image for larger version.
ID:	15981Click image for larger version.
ID:	15982Click image for larger version.
ID:	15983Click image for larger version.
ID:	15984Click image for larger version.
  2. #2
    Default Re: Chris Craft Cavalier with V8 Big Block to identify
    It's a 440
  3. #3
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    782
    The 440 ID stamp block is to the right of distributor, under the plug wires and alternator wires in your picture. That stamp block is on the RB (raised block) engines. 413, 426 (except hemi for this engine), and 440 are RB engines. Although the 426 hemi is a raised block there is much difference between the wedge and hemi head engine.
    Halfway down the page for a 440 manual...
    http://www.correctcraftfan.com/reference/manuals.asp
  4. #4
    Thanks for the fast reply !
  5. #5
    oil exhaust
  6. #6
    pictures of 2 exhaust where oil was dripping before we put random bolt just to stop oil dripping
ID:	18060Click image for larger version.
  7. #7
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    782
    Remove them and replace with the proper pipe plug?
  8. #8
    the thing is that when I found the engine back it was like that. So I have no idea if any and what was attached to those 2 parts..
  9. #9
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    782
    Maybe something here.
    Download this manual
    here...
    PDF Page 12 has a 426 wedge with taps for a remote oil filter I believe.
    PDF Page 65 shows a cooler and above it out of the picture a filter base.
  10. #10
    Since the filter is installed on the pump the fittings are most likely for an oil cooler. If the cooler was full flow then capping off the fittings could cut off oil pressure to the motor. I would suggest running a cooler, a high pressure hose between the fittings or (if not using a cooler) get another oil pump.
  11. #11
    Thanks, I'll have a closer look to that ! In the mean time I also found that it's definitely for an oil cooler and that I can even put 2 in series..
Similar Threads
  1. Want to identify and sell two Chris Craft motors
    By smwest in forum Miscellaneous marine engine topics
    Last Post: 01-07-2010, 04:32 PM
  2. 1962 chris craft cavalier
    By 62_cavalier in forum Chris Craft Engine Forum
    Last Post: 04-20-2009, 08:54 PM
  3. Can anyone identify this Chris Craft
    By capt_scott_miller in forum Chris Craft Engine Forum
    Last Post: 09-02-2008, 03:27 PM
  4. Help identify a Chris Craft engine
    By andrew in forum Chris Craft Engine Forum
    Last Post: 09-13-2006, 10:15 PM
  5. 1964 Chris Craft Cavalier water pump
    By tomcurtis in forum Chris Craft Engine Forum
    Last Post: 06-26-2006, 01:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
