Results 1 to 4 of 4
  1. #1
    Default Yanmar 2GM 2 cylinder 18hp. Fresh water under the engine?
    I've gone around and around with this engine.
    - First diesel smell. Leaky injector fixed.
    - still diesel! Found leak in tank pulled tank re welded installed. What a bitch that was
    - still water! Found that the exhaust mixing elbow had rotted through. Replaced
    no smell of diesel no leak on tank. Drop less packing gland. No observable drop even from the packing glad except underway. tiny.
    But now I still see about a gallon of water under engine after 2 hours motoring and just sitting. Strange thing going Ian it's not red like coolant freshwater, doesn't have fuel in it. And has NO salt taste!
  2. #2
    Default Re: Yanmar 2GM 2 cylinder 18hp. Fresh water under the engine?
    sorry for all the typos as I was doing by phone but I think you get the idea. can't sem to understand why there is seemingly salt-less freshwater with no coolant (red) collecting under the engine. any ideas would be appreciated.
  3. #3
    Quote Originally Posted by Dolesy View Post
    I would take a look at your water pump, Mine had a drip at idle and more under load. It was easy to rebuild.
  4. #4
    Quote Originally Posted by self-maintained-boater View Post
    thanks! I did finally determine it is sea water. most likely dripless packing gland or rudder seal.
    Chris
Similar Threads
  1. Replies: 10
    Last Post: 08-11-2011, 08:48 PM
  2. low compression on #2 cylinder after fresh rebuild. 1986 120 hp
    By bayliner trophy in forum Chrysler Force Outboard Forum
    Last Post: 02-11-2011, 09:42 PM
  3. 2 cylinder inboard yanmar engine
    By ivanbranch in forum Yanmar
    Last Post: 02-11-2011, 06:03 AM
  4. Flush fresh water coolant on Yanmar 4JH3DTE
    By rsudama in forum Yanmar
    Last Post: 05-28-2009, 01:43 PM
  5. LM318 engine fresh water still overheatingtried everything
    By eess34610 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 07-30-2007, 11:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
