Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 5 of 5
  1. #1
    Default Purchased Nissan NS8B 8 hp two-stroke. Couple Questions, thanks!
    Just purchased a used Nissan NS8B 8hp two-stroke. Base on the cowling I'm guessing it's an early 2000 model. Going to call Tohatsu to confirm. Runs great with low hours (prop and lower end shows very little wear). Freshwater use only so very little corrosion.
    Couple questions:
    1. We need to lay it down for transport in our 5th wheel trailer. I thought I saw somewhere where it suggested laying it down with the front of the engine (pull start) pointing up/prop facing down/tiller up. Is that correct? If not, which way.
    2. What would it take to boost output to 9.9 hp? Carb change?
    3. Any special issues or concerns with this particular motor?
    4. It's very difficult to find ethanol-free gas in AZ. Any problem using ethanol gas (10%) with this motor?
    Thank you!
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,212
    Default Re: Purchased Nissan NS8B 8 hp two-stroke. Couple Questions, thanks!
    1. Any orientation is fine. Keep in mind that you want the carb empty before laying it down.
    2. Nope. Depending on precise serial, maybe 9.8 with a carb change.
    3. Nope. Good motors; valued for their light weight and durability.
    4. E10 is OK; Must be Fresh (under 30 days). Run the carb out every day to reduce varnishing.
    Paul
    Buffalo NY USA
  3. #3
    Quote Originally Posted by pvanv View Post
    pvanv, thanks for the helpful replies. Good to hear this is a good motor! Was going to pull the trigger on a new Tohatsu 9.9 HP 4-stroke. Saw this for sale and took a chance. A lot lighter than the new Tohatsu 8/9.9 HP motors. Going to be using this with our inflatable that we carry in our RV. Weight and ease of storage were important.
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,212
    Tohatsu 9.9 4-strokes have not been available for years; replaced by the industry's-lightest-weight 4-stroke 9.8.
    Paul
    Buffalo NY USA
  5. #5
    Oops, typo--my bad. Thanks for catching that
Similar Threads
  1. 1998 Nissan 8HP / NS8B - How best to proceed??
    By 1OldWaterDog in forum Nissan Tohatsu Outboard Forum
    Last Post: 05-20-2014, 04:15 PM
  2. 1999 nissan ns8b two stroke powerhead removal
    By mc366 in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-30-2010, 06:21 AM
  3. Nissan NS8B question 2003 8 hp
    By tsmscscs in forum Nissan Tohatsu Outboard Forum
    Last Post: 03-29-2010, 05:13 PM
  4. Nissan 1998 NS8B
    By cheath in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-29-2009, 09:58 AM
  5. Nissan ns8b submerged
    By dcdunbar in forum Nissan Tohatsu Outboard Forum
    Last Post: 04-02-2009, 08:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
