New to me 13' Whaler with BF45.
Previous owner had a rat nest of wiring for bilge pumps, bait pumps, radio GPS etc, and the battery was just loose in the stern. I'm still in the process of cleaning up the wiring, the battery is now secured in a battery box in the correct location and the ONLY connections to the battery are the positive and negative heavy leads to the starter.
When the motor is running at ~2000 rpm there is no increase in voltage. The tach is working so I assume the coil is good. Pulled the rectifier and using a multimeter set to Diode, I get open circuit between white and all three grey wires, Open between white/black and all three grey wires, dead short between white and white/grey, and a dead short between two of the grey wires. Bad rectifier, right (want to be sure before ordering a new one)?
Also, the White wire has constant 12V even with the ignition off. Is this correct?
Thanks for any insight!
Matt
Matt
