Results 1 to 3 of 3
  1. #1
    Default 4.3 OMC bogs on accelleration
    1989 4.3 omc cobra bogs out upon acceleration. Replaced fuel pump, fuel filter, points and condenser, coil, water fuel separator, rotar, rebuilt carburetor, checked timing. Any ideas what else could be causing the problem?
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,445
    Default Re: 4.3 OMC bogs on accelleration
    Ayuh,.... Probably poor fuel flow,....
    Could be the tank, or the fuel in it,....
    What was in the fuel filter ya took off,..??
  3. #3
    I had similar problems. I put in some sea foam (fuel conditioner) and a new battery and it was happy.
    Even premium fuel will separate after a couple weeks.
    The problem I think I was having was that the altnator wasn't grounded properly and was sucking the juice out of the battery and just barley giving enough spark at a high load of throttle.
Similar Threads
  1. 4.3 bogs down
    By duckhunter185 in forum Mercruiser Sterndrive Forum
    Last Post: 02-18-2013, 04:57 PM
  2. 43 GL poor accelleration
    By superamund in forum Volvo Penta Gas Archive
    Last Post: 07-13-2008, 12:14 PM
  3. Bogs on take off
    By sidebottom in forum Johnson Evinrude Outboard Archive
    Last Post: 05-08-2008, 01:44 PM
  4. Merc 470 stalls during accelleration
    By kdrenshaw in forum Mercury Mariner Outboard Archive
    Last Post: 07-14-2007, 09:14 AM
  5. 115 bogs down
    By kdaven in forum Yamaha Outboard Archive
    Last Post: 01-19-2007, 03:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
