Click forPleasurecraft Marine parts and manuals!
Results 1 to 2 of 2
  1. #1
    Post Check engine light on after starting
    Engine goes into Power Reduction mode. Only allows engine to reach 2500 rpm, then it goes back to below 1200 rpm.
    water was in engine compartment.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,840
    Default Re: Check engine light on after starting
    the power reduction mode tells you the computer has found something 'wrong' but will still let the engine run....
    your best bet is to find someone with a scan tool and start the diagnosis..
Similar Threads
  1. Check engine light @ 3,000 rpm 8.1
    By slow cruiser in forum Crusader Marine Engine Forum
    Last Post: 07-05-2017, 11:07 PM
  2. Check Engine Light / alarm before starting - 2004 8.1
    By tyrenta in forum Crusader Marine Engine Forum
    Last Post: 04-06-2015, 01:56 PM
  3. Check engine light
    By Bradley1 in forum Suzuki Outboard Forum
    Last Post: 07-20-2014, 02:19 PM
  4. Check engine light
    By gettindeep in forum Johnson Evinrude Outboard Forum
    Last Post: 10-03-2011, 11:22 PM
  5. Check engine light
    By Anonymous in forum Outboard motors archive 2000-2004
    Last Post: 01-21-2001, 02:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
