Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 4 of 4
  1. #1
    Default Tohatsu 6hp runs better with engine cover off?
    My 2005 Tohatsu 6 hesitates and sputters a bit but as soon as you remove the cover the idle goes up and it accelerates normal? I have cleaned the carb thoroughly but my guess is its starving for air? Is there any kind of sensor on these?
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,196
    Default Re: Tohatsu 6hp runs better with engine cover off?
    Year of manufacture is irrelevant for servicing Tohatsu outboards; Model and Serial are what you need to have to describe the motor. Assuming your model is MFS6B. No, there isn't any O2 sensor of anything like that. Either the air inlet of the cowl is plugged, or the carb is way way too rich, or you have an exhaust leak.
    Paul
    Buffalo NY USA
  3. #3
    Quote Originally Posted by pvanv View Post
    xhuast hav ea wMFS6AS,
    Where do you think would be the most likely culprit for a exhaust leak? I do see some build up of oil and crud at the exhaust port plate under the head. Also I can smell exhaust right under the carburetor.
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,196
    Base Gasket perhaps.
    Paul
    Buffalo NY USA
Similar Threads
  1. runs better without cover.
    By Bstrsdad in forum Johnson Evinrude Outboard Forum
    Last Post: 04-29-2012, 02:02 PM
  2. yamaha 115 hp 4 stroke runs great witout engine cover
    By marylou cacciatore in forum Yamaha Outboard Forum
    Last Post: 07-10-2011, 10:15 PM
  3. Evinrude 28 special only runs well with motor cover off
    By captain_jim in forum Johnson Evinrude Outboard Archive
    Last Post: 08-15-2009, 11:47 AM
  4. 6hp sea horse runs ok cover off doesbnt with cover on
    By Steve Turner in forum Johnson Evinrude Outboard Archive
    Last Post: 02-27-2008, 08:20 AM
  5. 60 hp runs rough insulation on cover
    By buzzman9403 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-16-2006, 01:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
