Tiger Chet
<div>We have an issue with our boats fuel system. After putting the boat in the water for the 1st time this season, it ran just fine as I motored out the channel. With the channel cleared I trimmed it down and throttled up, the boat began to rumble loosing RPMs. It acted as if something was wrapped around the prop. It would not throttle up without stalling. The distance from the launch to home was just under 2miles. Idle RPM also began to drop off 1100 to 800 as I kept going. On the lift raised I inspected the outdrive and it was fine. Research showed me it was the fuel pump. I also noted a slight rise with my oil level about a pint, typical with GM pumps. I installed the new pump with some difficulty with the push rod. Now the pump has drawn fuel into the filter but has stopped just under full. Prior to the 1st start attempt I removed the filter, drained it inspecting for water. No water was in the system. With my spare filter installed "empty", system was dry all the way to the carb. This morning I blew air from the filter housing down into the tank. At first it seemed slightly plugged but now is clear. Should I try to prime the pump?<br><br><br>Tiger Chet <br></div>
