Results 1 to 5 of 5
  1. #1
    Default Marine Power 5.7 carb alarm buzzer 2nd set of sender locations
    I have a marine power 5.7 vortec carburated engine. I want to install an alarm buzzer kit that includes its own set of oil and water temp senders. Im not sure where I can install the additional set of senders on the block. I have located the oil and water senders for the gauges but there are no additional ports near them that I can see. Hoping someone can help me out.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,163
    Default Re: Marine Power 5.7 carb alarm buzzer 2nd set of sender locations
    Your kit should have switches (vs sending units)....
    You have two options: 1) get the correctly sized T and a pipe nipple and use the ports where the existing sending units go or 2) find another pipe plug in the respective galley and install the switches there....a good mechanic will usually point out viable locations for a few cold ones....
  3. #3
    Quote Originally Posted by makomark View Post
    Thanks for the help. I think Iíll use the T-fitting method.
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,163
    no problem.....
    Tip: use the 'smallest' T and nipple that will get the job done.....the idea is to minimize any 'moment arm' effect driven by vibration
    or wave action....and use decent material....so you minimize any fatigue in the future....
  5. #5
    no problem.....
    Will do. Thanks.
Similar Threads
  1. buzzer/alarm
    By brianda in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 10-13-2016, 01:48 PM
  2. Marine power 454 backfires through carb under load?
    By fishkiller1 in forum Marine Power Engine Forum
    Last Post: 06-04-2015, 09:07 PM
  3. marine power 5.7 overheat buzzer
    By mainer04911 in forum Marine Power Engine Forum
    Last Post: 02-10-2011, 08:55 PM
  4. Alarm Oil Pressure Sender Outdrive Oil
    By ehlien in forum Mercruiser Sterndrive Archive
    Last Post: 08-14-2009, 11:52 PM
  5. Yamaha F150 alarm types and locations
    By warty in forum Yamaha Outboard Archive
    Last Post: 08-30-2008, 05:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
