MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default Merc 9.9 2 stroke water ingestion lower cylinder
    I have a 89 Merc 9.9 That runs rough at idle and higher speeds. Lower plug always looks wet/grey emulsion and with small water droplets
    Compression good at 105 PSI in both, gas is fresh and 50:1
    Cylinder leak down test at 4%
    New plugs installed, both getting good spark. (has aftermarket CDI box)
    Carb was taken apart and was clean. Fuel needle/seat held pressure for 10 min, float set to 1 inch
    Reeds appeared to be good and sealed tight
    Float was good and main jet clean
    Low speed jet at 11/4 turns out
    I have already replaced exhaust plate gaskets with no better results. When I bough the motor, the impeller was shot, so it may have been overheated at one time...
    Some have told me lower seal may be bad. Dealer says he thinks that is unlikely. I
    s there any other way for water from cooling system to enter the cylinder?
  2. #2
    Default Re: Merc 9.9 2 stroke water ingestion lower cylinder
    Was getting too far into this engine so I ended up scraping it...
  3. #3
    Hope you sold the lower unit for a good price. They are pretty desirable.
  4. #4
    Quote Originally Posted by flyingscott View Post
    Yes, I got $500 CAD for it without the prop
Similar Threads
  1. water leaking slowly out above my lower unit...what is happening? (1981 Merc 25hp 2 stroke)
    By aspettapernessuno in forum Mercury Mariner Outboard Forum
    Last Post: 02-17-2016, 08:27 AM
  2. Water Ingestion
    By coupleadays in forum Mercury Mariner Outboard Forum
    Last Post: 06-14-2011, 01:17 AM
  3. Merc 57 1986 water ingestion questions
    By jiggamurf in forum Mercruiser Sterndrive Archive
    Last Post: 08-12-2009, 10:44 PM
  4. 82 merc water ingestion
    By mike giard in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 03-06-2006, 06:51 PM
  5. Water ingestion
    By paulw in forum Archive 2002-2006
    Last Post: 06-25-2002, 07:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
