Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 4 of 4
  1. #1
    Default Tohatsu 25HP M25c3 engine won't tilt
    Hi all,
    I'm fairly new to the marine world but am now the proud owner of a 2006 tohatsu 25hp M25c3 2 stroke (on a 13ft Dory) !
    With the engine mounted on the transom when I try to tilt the engine up it won't tilt. It used to absolutely fine. There is a small clip that engages it to the adjustable pin for the trim. As far as I'm aware this clip should only be engaged when the engine is in reverse to stop the thing tilting up and out the water when thrust is applied. The clip is now engaged in forward neutral and reverse which I'm sure it shouldn't be?
    You can manually lift the clip to release the engine but it should be free when in forwards in case you hit an obstruction then the engine can ping/tilt up and therefore not rip off the transom.
    So I guess what I'm asking is has anyone else had this problem and do you know how to fix it please?
    Thanks for any help in advance! Tom
ID:	15898Click image for larger version.
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    Default Re: Tohatsu 25HP M25c3 engine won't tilt
    Flip the reverse lock lever (with the red tip), and you should be OK.
    Paul
    Buffalo NY USA
  3. #3
    Hi, thanks for that but still unable to lift with reverse lock released!
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    It's a simple mechanism. The lever operates the catch. Look to see what is happening.
    Paul
    Buffalo NY USA
Similar Threads
  1. Tohatsu 25hp M25B
    By altered888 in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-03-2014, 11:44 AM
  2. Replies: 2
    Last Post: 07-30-2011, 05:18 PM
  3. M25C3 WOT issues
    By weimgator in forum Nissan Tohatsu Outboard Forum
    Last Post: 01-01-2010, 02:43 PM
  4. M25c3 cylinder repair
    By boat_e in forum Nissan Tohatsu Outboard Forum
    Last Post: 11-30-2009, 11:30 AM
  5. 93 tohatsu 25hp clogged
    By phillip8932000 in forum Nissan Tohatsu Outboard Forum
    Last Post: 06-15-2009, 07:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
