"Thank you for your reply. I will let you know how it works. Sincerely, JanAfter installing new carb did you time and sync all 4 carbs per your service manual?
You need a carb sync tool. You will never get it running right with out it.
This will help.
https://www.youtube.com/watch?v=l4dGC1p_2uM
We used the manometer to synch the carbs. the #4 carb is new and is still missing. What are other areas we need to check? Thank you.
Other 3 carbs are fine. Already adjusted hex bolt, etc.
