Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 2 of 2
Thread: kill wire
  1. #1
    Default kill wire
    I have a 1987 bayliner with a 125 force I am trying to diagnose a no spark condition and cannot locate the kill wire on the motor side anyone please help
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,513
    Default Re: kill wire
    The white wire is the kill wire.
    No spark?
    Low battery, bad stator, flywheel key sheared, bad regulator, bad connections?
    outboardignition.com has test procedures for this motor.
    On the buss bar unhook the white wire and see if the motor starts??
    Unhook the regulator and see if it fires??
    Unhook the tach and see if it fires??
    You sure the kill switch is working?
    Possible?? there is a fuse under the dash that can go bad.
    The contacts get corroded and it can cause a no spark condition.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
Similar Threads
  1. 1992 evinrude 60hp no spark, kill switch wire location
    By NTXbighorn93 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-18-2014, 07:39 PM
  2. 1992 40HP Force Kill Wire Question
    By ko4nrbs in forum Chrysler Force Outboard Forum
    Last Post: 07-22-2014, 10:41 PM
  3. Wire for a kill switch
    By Beagleman in forum Mercury Mariner Outboard Forum
    Last Post: 03-04-2013, 03:23 PM
  4. Kill wire question
    By easy in forum Mercury Mariner Outboard Archive
    Last Post: 05-22-2009, 10:09 AM
  5. Correct routing for kill wire on 125 Force Motor
    By jim f in forum Chrysler Force Outboard Archive
    Last Post: 12-11-2005, 12:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
