Results 1 to 6 of 6
  1. #1
    Default Johnson 35hp 1981. Put in new water pump. Can't line up the 2 pipes & shaft - trick?
    I have struggled a few hours to get drive shaft engaged, water tube in and plastic shaft spacer connected and see to know they are all home when the foot is fully mated to exhaust tube. What is the trick? Can get copper tube started and drive shaft splines engaged But the plastic spacer tube is hidden before the last o-ring goes home in one end - tried either end - no luck. Please share the trick!!!!!
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: Johnson 35hp 1981. Put in new water pump. Can't line up the 2 pipes & shaft - trick?
    You have to turn the flywheel to get splines to line up.
  3. #3
    Have driveshaft splines engaged OK, also copper water tube into power-head ok. Driveshaft spacer (plastic) engaged in pump per instructions, but top of spacer ( with o-ring) will not locate and slide into it's receptacle inside of exhaust tube. How can you get this alignment? Can't see or touch the plastic spacer tube because the foot (gearbox) is within 1/2 inch of mating completely to exhaust tube. Please review my original post information.
  4. #4
    That tube only goes in 1 way you need to align the flat spot on the collar. I believe the flat should face the front of the motor I could be wrong you may have to play with it.
  5. #5
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Should take just minutes.---Done it many times.---------Put the plastic tube into the exhaust housing first !
  6. #6
    Thanks raceone! Going out to shop to try that again. Tried that too, but only once then. Will give anther few tries!
Similar Threads
  1. 1978 johnson 35hp. replaced water pump, and its still not peeing.
    By AKCHILLIN in forum Johnson Evinrude Outboard Forum
    Last Post: 06-04-2014, 05:52 PM
  2. 1980 35HP Evinrude Long Shaft Top Of Water Pump Spacer Cut?
    By duurmeehr in forum Johnson Evinrude Outboard Forum
    Last Post: 11-27-2012, 03:27 PM
  3. 1981 Merc 140Pressure line from bottom of hydraulic pump
    By tymegoesbye in forum Mercruiser Sterndrive Archive
    Last Post: 09-06-2008, 10:10 PM
  4. 1981 Johnson 35hp
    By johnd in forum Johnson Evinrude Outboard Archive
    Last Post: 06-27-2008, 11:20 AM
  5. 1981 35hp johnson short shaft
    By dynomite00 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-27-2006, 09:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
